Z1194
  • 5
Message 1 of 7
Slow Speed
Good Morning,
I have been experiencing slow speed on my connection since yesterday afternoon. There were intermittent connection issues yesterday morning however this was I believe down to a known fault in the area.
I've gone through the online help and connection test to  no avail. All cables have been checked for tightness and security and multiple resets of the HUB have been completed with a hard reset using the pinhole on the back.
Usually the hub is operated in modem only mode and is connected through a Netgear R7800 with hard wired connections to most devices in the house through 2 Netgear GS305 un-managed switches. Wireless connections are for mobile devices and IOT devices.
331000000
Locked
Ranged Upstream Channel (Hz)
25799998
Locked
Provisioning State
Online
13310000004.538256 qam25
1Locked38.600
1257999984.425512064 qam4
General Configuration
Network access
Allowed
Maximum Number of CPEs
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
foA,.iyewrkldJKDHSUBsgvca69834n
SFID19325
Max Traffic Rate402500089
Max Traffic Burst42600
Min Traffic Rate0
Primary Upstream Service Flow
SFID28792
Max Traffic Rate38500089
Min Traffic Rate0
Max Concatenated Burst42600
Scheduling TypeBestEffort
01/01/1970 00:01:22Warning!MDD message timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:01:22Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
18/09/2020 09:02:47noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:01:21Warning!MDD message timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:01:21Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
18/09/2020 08:49:16noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:01:20Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
18/09/2020 08:21:14noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:01:39criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:01:24Warning!MDD message timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:01:24Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:01:20Warning!MDD message timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
18/09/2020 08:01:24noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
18/09/2020 07:56:20Warning!MDD message timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
18/09/2020 07:56:20Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
18/09/2020 07:56:1criticalReceived Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
18/09/2020 07:55:15criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
18/09/2020 07:28:2noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
I've just configured a BQM as well through looking at other posts and will post this if required when data has been collected.
I look forward to your responses.
Z
Z1194
  • 5
Message 2 of 7
Re: Slow Speed
This was a speed test completed a few seconds ago with a brand new CAT5e (just taken out the wrapper) Ethernet cable directly into the Superhub 3 on an M350 package.Usually looking at around 380mbps across the network at home.
https://www.speedtest.net/result/10105264362
18-Sep-2020 135018-Sep-2020 1350
Link to BQM currently populating.
https://www.thinkbroadband.com/broadband/monitoring/quality/share/dfb72672a3cea5ac2216235e3a8618c735...
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 3 of 7
Re: Slow Speed
It is not surprising that your connection is so bad.
You have 1 Downstream Channel, you should have 24.
You have 1 Upstream Channel, you should have either 2 or 4.
You need an engineer visit to put things right.
You can contact VM to report the problem using ...
Text service on 07533051809
150 from Virgin landline.
0345 454 1111 from any other UK  phone.
The best time to call is weekdays 08:00 to get a UK agent, anything after 10:00 you must realise that you are quite likely to get through to an offshore agent that doesn't speak English as a first language.
Or you can wait on here for one of the VM Staff to pick up the thread but this may take a few days.
Z1194
  • 5
Message 4 of 7
Re: Slow Speed
Thanks Mike.
I’ve tried a text yesterday, no reply yet.
I’m on hold currently as it’s still not playing ball.
Can’t even perform a speed test now because it keeps failing.
Will wait and see what happens I guess.
Tags (1)
Z1194
  • 5
Message 5 of 7
Re: Slow Speed
Well after 2 hours on the phone hopefully have a technician coming out on Monday.
Z1194
  • 5
Message 6 of 7
Re: Slow Speed
Miraculously Sunday everything was fine.
After being told over the phone two separate times that nothing was wrong in the local area and nothing showing on the service pages. I suddenly had 24 downstream channels locked and 4 upstream locked and the service was back to normal.
If a Virgin media mod does come across this it would be nice to get an explanation as to what happened as we were without service for 3 days and I'd like to get a better understanding so that when I phone next I can ask the right questions as myself and the wife are both working from home currently.
Either way see current status of virgin router:
Channel Frequency (Hz)Power (dBmV)SNR (dB)ModulationChannel ID
13310000004.438256 qam25
22030000004.137256 qam9
32110000003.537256 qam10
42190000003.237256 qam11
52270000002.937256 qam12
62350000002.537256 qam13
72430000002.537256 qam14
82510000002.537256 qam15
92590000002.237256 qam16
102670000002.237256 qam17
112750000002.437256 qam18
122830000002.537256 qam19
132910000003.537256 qam20
142990000004.537256 qam21
153070000004.438256 qam22
163150000004.838256 qam23
17323000000538256 qam24
183710000004.838256 qam26
193790000004.138256 qam27
203870000003.738256 qam28
213950000003.538256 qam29
224030000003.237256 qam30
234110000003.238256 qam31
244190000003.238256 qam32
1258000074.425512064 qam4
2326000684.425512064 qam3
3394000294.575512064 qam2
4462000954.575512064 qam1
21/09/2020 08:09:0criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
19/09/2020 18:54:14noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
19/09/2020 14:21:43criticalReceived Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
19/09/2020 11:08:59noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
19/09/2020 08:22:37criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
19/09/2020 06:56:52noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
Jodi_S
  • 2.14K
  • 121
  • 226
Message 7 of 7
Re: Slow Speed
Hi Z1194,
Thanks for the update with how things have been since Sunday. Unfortunately we do not know what was causing the issues for the 3 days where you without internet services.
It is really strange how when you have called our service status line no fault was showing even though there clearly was with your downstream levels.
Was a technician booked to come out and take a look at this for you? Generally with downstream issues we would recommend a technicians visit to investigate this further for you.
Please let us know how it has been since your last post and we will double check your levels for you again.
Kind regards Jodi
