skillboy
  • 29
Message 1 of 14
Slow Speed with Dropped Packets
Hi All
I am currently on M500 Package and My speeds seem to vary throughout the day, sometimes I can receive 400Mbps then sometimes this drops down to 150Mbps and noticed last night that this was very slow and kept lagging while gaming.
I have done some ping testing today and seen that I have had a few dropped packets to google.
When the broadband was installed the Engineer checked the line and said a comment about the cabling as he was getting a poor signal.
I will upload the BQM Graph and also the power signal levels and hopefully one of the VM forum Assistants can pick this up and get a engineer booked, may possibly need to be re cabled from the street to the house.
https://www.thinkbroadband.com/broadband/monitoring/quality/share/069d86ada9c01550c64d725aed357a1e1f0545b9-06-01-2021
11950000006.640256 qam8
21390000007.140256 qam1
31470000007.340256 qam2
4155000000740256 qam3
5163000000740256 qam4
6171000000740256 qam5
7179000000740256 qam6
8187000000740256 qam7
92030000006.540256 qam9
102110000006.440256 qam10
112190000006.340256 qam11
122270000006.340256 qam12
13235000000640256 qam13
142430000005.940256 qam14
152510000005.540256 qam15
162590000005.440256 qam16
172670000005.840256 qam17
182750000005.940256 qam18
19283000000640256 qam19
20291000000640256 qam20
212990000006.540256 qam21
22307000000640256 qam22
233150000006.140256 qam23
24323000000640256 qam24
1Locked40.340
2Locked40.900
3Locked40.350
4Locked40.360
5Locked40.300
6Locked40.300
7Locked40.300
8Locked40.940
9Locked40.950
10Locked40.940
11Locked40.360
12Locked40.350
13Locked40.300
14Locked40.900
15Locked40.900
16Locked40.900
17Locked40.360
18Locked40.940
19Locked40.300
20Locked40.950
21Locked40.950
22Locked40.900
23Locked40.300
24Locked40.300
16030000036.8512064 qam1
23940000234.8512064 qam4
34620000235.3512064 qam3
45370002436.8512064 qam2
3ATDMA0000
4ATDMA0000
skillboy
  • 29
Message 2 of 14
Re: Slow Speed with Dropped Packets
General Configuration
Network access
Allowed
Maximum Number of CPEs
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
a69834ncxv9873254k;fg87dsfd;k
SFID3528
Max Traffic Rate575000000
Max Traffic Burst42600
Min Traffic Rate0
Primary Upstream Service Flow
SFID3527
Max Traffic Rate38520000
Min Traffic Rate0
Max Concatenated Burst16320
Scheduling TypeBestEffort
Also The SH3 is currently in Modem Mode with a Netgear X4s 7800 router.
All tests have been conducted Via Lan using a CAT 6 and plugged directly into the router.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 3 of 14
What speeds do you get at >>  SamKnows << with a direct connection using a Cat 5E or better ethernet cable between the Hub in Router Mode and a 1Gbs capable Pc/Mac/Chromebook and no other devices connected ?
skillboy
  • 29
Message 4 of 14
Ran the speed test on a Laptop running win 10 and running Core I7 Processor with a Gigabit Lan adapter installed
Latency 20.9ms
Jitter 4.00ms
Download 188 Mbps
Upload 23.8Mbps
Ran the speed test with WiFi turned off from the Netgear router to minimise any network traffic from other devices.
The Coaxial cable is pushed in all the way and is not loose from the SH3
skillboy
  • 29
Message 5 of 14
Connection was bad again last night when trying to play online games
Here is the BQM graph for yesterday.
https://www.thinkbroadband.com/broadband/monitoring/quality/share/ea8b841c303f6337205feed7cb093bb706119954-11-01-2021
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 6 of 14
Can you test again without the Netgear in the LAN, it needs to be Hub to PC with only the cable between.
skillboy
  • 29
Message 7 of 14
Just completed this with the following results
Latency 19.1ms
Jitter 2.81ms
download 131Mbps
upload 32.1 Mbps
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 8 of 14
Your >> BQM << is showing some latency but it could be a lot worse.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 9 of 14
Can you test with a different cable Cat 5e or better cable please.
skillboy
  • 29
Message 10 of 14
This test was with a Cat 6 cable.
I have done another test with a brand new Cat 6 cable and have got these results
Download 118Mbps
Upload 32.2Mbps
Also Latency seems high to reach google.co.uk
Pinging google.co.uk [216.58.210.195] with 32 bytes of data:
Reply from 216.58.210.195: bytes=32 time=48ms TTL=116
Reply from 216.58.210.195: bytes=32 time=50ms TTL=116
Reply from 216.58.210.195: bytes=32 time=46ms TTL=116
Reply from 216.58.210.195: bytes=32 time=53ms TTL=116
Reply from 216.58.210.195: bytes=32 time=43ms TTL=116
Reply from 216.58.210.195: bytes=32 time=42ms TTL=116
Reply from 216.58.210.195: bytes=32 time=49ms TTL=116
Reply from 216.58.210.195: bytes=32 time=45ms TTL=116
Reply from 216.58.210.195: bytes=32 time=62ms TTL=116
Reply from 216.58.210.195: bytes=32 time=54ms TTL=116
Reply from 216.58.210.195: bytes=32 time=13ms TTL=116
