Mobyd
  • 7
Slow Speed since Transferring to Hub 4 and 1GB Service.
      I transferred from the M200 Internet package to 1GB. Since changing the router, my steady connection at 200Mb has gotten a lot worse, dropping to 20 MB in some cases. I have done multiple reboots of the router checking all the cables but no joy. Any one got any ideas?
I have run the speed test via Wifi and a laptop lugged in direct to the router via a CAT6 cable. Any ideas?
Here's my config file if this helps?
General Configuration
Network access
true
Maximum Number of CPEs
1
Baseline Privacy
true
DOCSIS Mode
3.1
Config file
87dsfd;kfoA,.iyewrkldJKDH
SFID
11414
Max Traffic Rate
1200000450
Max Traffic Burst
42600
Min Traffic Rate
0
Primary Upstream Service Flow
SFID
11413
Max Traffic Rate
55000270
Max Traffic Burst
42600
Min Traffic Rate
0
Max Concatenated Burst
16320
Scheduling Type
bestEffort
Any ideas?
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Re: Slow Speed since Transferring to Hub 4 and 1GB Service.
What speed do you get at >> Sam Knows Real Speed << using a direct connection using a Cat 5E/6 cable between the Hub in Router Mode and a 1Gbs capable Pc/Mac/Chromebook and no other devices connected ?
Mobyd
  • 7
     Thanks for getting back in contact. My details are as follows:
This is strange. I get a really slow speed on Speedtest.net and keep getting performance issues with Video chats and stuff
Not sure if this is a connection issue or a router issue.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Can't see your image, it needs authorising for for public viewing.
speedtest.net is not a very good test site for 1Gbs.
You are better off using Sam Knows Real Speed as advised above.
Mobyd
  • 7
No Worries. It was blockedas it showed my IP address. Things seemed to have picked up. Now I just need to get the phone line sorted. just awaiting a call back from them to sort it.
Mobyd
  • 7
Thanks for your help 🙂
