Josh90b
  • 39
Message 1 of 17
Slow Speed since Thurs 25th June
Hello,
I've had consistent extremely slow speeds since Thursday the 25th of June at around 11pm. This happened before back in April/May but was fixed the following Tuesday morning. I've followed all the step by step guides on the help centre but still nothing fixed. Had no luck getting through to anybody via phone.
I'm in the SW area. This needs to be resolved immediately as I am strongly thinking of leaving after being a customer for a number of years.
Josh
Tags (1)
gary_dexter
  • 30.52K
  • 1.89K
  • 4.05K
Message 2 of 17
Re: Slow Speed since Thurs 25th June
What’s slow exactly?
Wired or wireless devices?
Josh90b
  • 39
Message 3 of 17
Getting huge latency when trying to stream. Using Ethernet cable on my laptop and my iPhone. Both can barely keep a steady stream on Netflix.
It happened before back in April/May and was announced that it would be fixed and it was. Like 3 days after. Now it's back and it's been over a week with no fix or mention. It happened right around when London started having issues last week so figured it was related but now I'm starting to think otherwise.
gary_dexter
  • 30.52K
  • 1.89K
  • 4.05K
Message 4 of 17
Do you have a BQM set up?
Josh90b
  • 39
Message 5 of 17
No, I've never used a quality monitor. I use a cloud gaming service and that usually tells me if my internet is sucking. Which it has done now since it went down last Thursday. Getting like 500 ms Latency. Netflix, Facebook all the web browsing is slow. So I'm almost certain it's an issue Virgin's end.
The test I ran on the Virgin website says it was slow but when you go back to the main page for problems in area, there're none.
gary_dexter
  • 30.52K
  • 1.89K
  • 4.05K
Message 6 of 17
Virgin will want to see a BQM so suggest setting one up.
Also post back the network, upstream and downstream logs from the hubs admin pages
Josh90b
  • 39
Message 7 of 17
I just ran a BQM after signing up for the first time. I'm not that tech savvy so could you explain the Hub info I need to get?
Here's the results to the test https://www.thinkbroadband.com/speedtest/1593796787107349555
Josh90b
  • 39
Message 8 of 17
  • 22.48K
  • 2.4K
  • 4.02K
Message 9 of 17
the first link is to their speed test - not the BQM
Josh90b
  • 39
Message 10 of 17
Is there a way I can speak to a member of Virgin Media team about this? I've tried calling and spent nearly £10 credit on hold... I thought there was a chat support.
