Thanks John, unfortunately none of this has really helped.
The various different connections, cables, I also tested my laptop at work via ethernet where it gives high speeds, so I do not think it is to do with my laptop nor cable(s).
Tried the hub reset, tried the speedtest on both Chrome and Edge and same results, about 10 down and 50 up, so upload is always fine, the download is very low versus the target.
May try some more over the weekend but something is wrong since all of this used to work fine before my holidays.
K-
