2ilver
  • 10
Message 1 of 17
Slow Speed from Superhub4
I upgraded from the M350/Superhub3 pack to the 1Gig/Superhub4. Set up the Hub4 today in Router mode and the wired connection speed was 200mbps and wireless,180mbps. Then set up the Hub4 in Modem mode and connected it to a TP Link Archer C9, same as my previous Hub3 setup. Speeds were similar to the Router mode. The M350 pack was consistently delivering around 300mbps previously. All speeds measured on Speedtest.net with CAT 7 cable for the wired connection and Galaxy S20 for the wireless. Latest firmware installed in Hub4.
Called customer service who ran a few checks and advised service on VM's side was fine. I was asked to run a speed test on SamKnows (VM's preferred option for 1GB speeds). This test showed 1Gig to the Hub4 but only 180mbps from the Hub4 (wired and wireless. So, the speed issue appears to be from the HUB4 to the wired/wireless clients. Customer service was not able to assist any further and suggested that I could try a "booster" device when it was back in stock. However, I cannot see how this would assist.
My intention was to use the Hub4/1Gig pack with an Asus Zenwifi AX8 Wifi 6 router. However, I feel there will be zero benefit until the speed from the Hub4 is actually delivering the intended speed.
I note from the Forum that a number of other users are having speed related issues but I cannot readily find a solution that applies to me. These are stats at the time of writing from speedtest.samknows.com:
Latency
24.2 ms
Jitter
9.20 ms
Download
170 Mbps
Upload
34.7 Mbps
Any advice/assistance would be greatly appreciated.
Many thanks
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 2 of 17
Re: Slow Speed from Superhub4
What speeds do you get at >> Sam Knows Real Speed << with a direct connection using a Cat 5E or better ethernet cable between the Hub in Router Mode and a 1Gbs capable Pc/Mac/Chromebook and no other devices connected ?
2ilver
  • 10
Message 3 of 17
170mbps
Anonymous
Not applicable
Message 4 of 17
Could you check the 'Configuration' tab in your router stats?
34.7 Mbps upload feels like you are still on M350.
2ilver
  • 10
Message 5 of 17
Re: Slow Speed from Superhub0
SamKnows shows 1Gb in to Hub4 but only 170Mbps out on a wired connection with a CAT 7 cable. Upload speed ranges from 30 to 50Mbps.
What upload speed would you expect from a 1Gb wired connection?
Anonymous
Not applicable
Message 6 of 17
A consistent 50 - 52Mbps.
Can you post the 'Downstream', 'Upstream', and 'Network Status' logs as text so we can have a look at the power levels, errors, etc.?
2ilver
  • 10
Message 7 of 17
Router Status in Modem Mode:
Cable Modem StatusItem Status CommentsChannel Overview Downstream Upstream
Cable Modem Status
Online
DOCSIS 3.1
Primary downstream channel
Locked
SC-QAM
DOCSIS 3.0 channels
31
4
DOCSIS 3.1 channels
1
0
2ilver
  • 10
Message 8 of 17
Downstream
3.0 Downstream channels
253310000009.50000038.605377QAM25625
113900000011.30000336.386890QAM2561
214700000010.90000236.609653QAM2562
315500000010.80000337.355988QAM2563
416300000010.50000037.636276QAM2564
517100000010.19999737.355988QAM2565
61790000009.69999736.609653QAM2566
71870000009.30000336.386890QAM2567
81950000009.09999836.609653QAM2568
92030000008.80000337.355988QAM2569
102110000008.69999737.636276QAM25610
112190000008.30000337.636276QAM25611
122270000007.80000337.355988QAM25612
132350000007.50000037.355988QAM25613
142430000007.80000337.355988QAM25614
152510000007.69999737.355988QAM25615
162590000008.30000337.355988QAM25616
172670000009.30000337.636276QAM25617
182750000009.59999837.636276QAM25618
192830000009.19999738.605377QAM25619
202910000009.19999738.605377QAM25620
212990000009.50000037.636276QAM25621
2230700000010.00000038.605377QAM25622
2331500000010.30000338.605377QAM25623
2432300000010.40000238.605377QAM25624
263390000008.80000337.636276QAM25626
273470000008.59999838.605377QAM25627
283550000008.59999837.636276QAM25628
293630000008.30000337.636276QAM25629
303710000007.90000237.636276QAM25630
313790000007.59999837.636276QAM25631
25Locked000
1Locked11500
2Locked3470
3Locked448928500
4Locked276500
5Locked11500
6Locked156900
7Locked452600
8Locked276500
9Locked156900
10Locked156900
11Locked430616500
12Locked276500
13Locked54100
14Locked3400
15Locked276500
16Locked287800
17Locked3400
18Locked3400
19Locked276500
20Locked276500
21Locked3400
22Locked3400
23Locked276500
24Locked3400
26Locked3400
27Locked528000
28Locked476300
29Locked54700
30Locked3400
31Locked775428100
3.1 Downstream channelsChannel Channel Width (MHz) FFT Type Number of Active Subcarriers Modulation (Active Profile) First Active Subcarrier (Hz)
159964K1880QAM4096759
3.1 Downstream channelsChannel ID Lock Status RxMER Data (dB) PLC Power (dBmV) Correcteds (Active Profile) Uncorrectables (Active Profile)
159Locked 6.734862990
2ilver
  • 10
Message 9 of 17
Upstream
3.0 Upstream channels
16030000037.0205995120 KSym/sec64QAM9
23940000035.5205995120 KSym/sec64QAM12
34620000036.0205995120 KSym/sec64QAM11
45370000036.5205995120 KSym/sec64QAM10
1US_TYPE_STDMA0000
2US_TYPE_STDMA0000
3US_TYPE_STDMA0000
4US_TYPE_STDMA0000
2ilver
  • 10
Message 10 of 17
Configuration
General Configuration
Network access
true
Maximum Number of CPEs
1
Baseline Privacy
true
DOCSIS Mode
3.1
Config file
wrkldJKDHSUBsgvca69834ncx
SFID
6898
Max Traffic Rate
1200000450
Max Traffic Burst
42600
Min Traffic Rate
0
Primary Upstream Service Flow
SFID
14966
Max Traffic Rate
55000270
Max Traffic Burst
42600
Min Traffic Rate
0
Max Concatenated Burst
16320
Scheduling Type
bestEffort
