abecet
  • 7
Slow Speed at Night
At nights the internet gets downto 8-10Mbits.. althought in the mornings it goes up to its normal speed ~104-110Mbits..
I am experiencing this since installation, my house is next to the switch box, and the intallation engineer said I should have the full speed without doubt.
I tried with different devices and different locations (right under the router even) it doesn't change, there is no radio wave interference also, since I'm standing next to the router and in the mornings it just works fine.
Can you please help me with this?!
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Re: Slow Speed at Night
If nothing is showing try phoning 0800 561 0061, this will tell you of more local issues that may be affecting your district. Be aware that it isn't a manned line.
Go round all the accessible internal and external co-ax connections and ensure that they are finger tight.
If everything above is OK we need do some more troubleshooting; to start with …
Disable any VPNs that you have running.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Can you please
