dansaville
  • 6
Message 1 of 13
Slow Speed M200
Hey everyone,
I have the M200 package and the speed is far away from 200Mbs. Usually was around 80Mbs until the last 2 weeks when the speed drops to 30Mbs. Now is a fluctuation between 30Mbs and 60Mbs. There is no change after reboot and fault checker. I'm connected directly to the superhub via ethernet cable. Any idea about what is going on? Many thanks for your time.
138750000
Locked
Ranged Upstream Channel (Hz)
53700054
Locked
Provisioning State
Online
11387500001040256 qam1
21467500001040256 qam2
31547500009.540256 qam3
41627500009.840256 qam4
51707500009.640256 qam5
61787500009.540256 qam6
71867500009.340256 qam7
81947500009.340256 qam8
92027500009.140256 qam9
102107500009.440256 qam10
112187500009.540256 qam11
122267500009.540256 qam12
13234750000940256 qam13
14242750000940256 qam14
15250750000940256 qam15
162587500009.140256 qam16
17266750000940256 qam17
182747500008.940256 qam18
192827500008.940256 qam19
20290750000940256 qam20
212987500009.140256 qam21
223067500008.840256 qam22
23314750000940256 qam23
243227500008.640256 qam24
1Locked40.9200
2Locked40.990
3Locked40.3300
4Locked40.9440
5Locked40.3250
6Locked40.3290
7Locked40.3690
8Locked40.3220
9Locked40.3370
10Locked40.3260
11Locked40.3300
12Locked40.370
13Locked40.3320
14Locked40.3200
15Locked40.3380
16Locked40.3190
17Locked40.3220
18Locked40.3240
19Locked40.3140
20Locked40.3270
21Locked40.3360
22Locked40.3410
23Locked40.9160
24Locked40.3650
1537000543.675512064 qam8
2462000003.6512064 qam5
3394000003.55512064 qam6
4326000903.5512064 qam7
SFID181684
Max Traffic Rate230000061
Max Traffic Burst42600
Min Traffic Rate0
Primary Upstream Service Flow
SFID181683
Max Traffic Rate22000061
Min Traffic Rate0
Max Concatenated Burst42600
Scheduling TypeBestEffort
Tags (3)
Buffer6
  • 11.21K
  • 93
  • 632
Hero
Message 2 of 13
Re: Slow Speed M200
If you are in router mode if not change to router mode
Then log in to your Hub and Click on Connected devices
and tell us your connection speed to the Hub
Run a speed test and keep an eye to that page and see if the connection speed changes
dansaville
  • 6
Message 3 of 13
Re: Slow Speed M200
Thanks for the reply I'm not in router mode I'm in modem mode. Ill switch back and try the above. Thanks for your help
dansaville
  • 6
Message 4 of 13
Re: Slow Speed M200
Just checked my connection speed to the Hub is 1000Mbps. It doesn't seem to change when I do a speed test.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 5 of 13
Re: Slow Speed M200
I think you may be mistaking the LAN speed and Wan speed.
What speed do you get at >> speedtest.net << using a direct connection using a Cat 5E/6 cable between the Hub in Router Mode and a 1Gbs capable Pc/Mac/Chromebook and no other devices connected ?
dansaville
  • 6
Message 6 of 13
Re: Slow Speed M200
Ah ok I have done that as well and its coming out at 47Mbps.
Dan
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 7 of 13
Re: Slow Speed M200
C can you do a 5 minute reboot on the Hub to see if the Hub can renegotiate a decent connection.
Switch the Hub off using the small switch on the rear of the Hub next to the power cord and pull the PSU plug from the wall socket.
Give it a good 5 minutes put the plug back in and switch the Hub back on.
Allow the Hub a few minutes to fully restart then do another speed test.
dansaville
  • 6
Message 8 of 13
Re: Slow Speed M200
Thanks for the help Mike ill switch it off shortly and let you know the results.
Gareth_L
  • 6.95K
  • 424
  • 781
Message 9 of 13
Re: Slow Speed M200
Hello dansaville
Thanks for your post and sorry to hear about the slow speeds
I have ran a quick check on your hub and can see it has been on for 14 days
Did you manage to switch it off like you were advised
If not can you try is now please
Also 2 of your downstream levels are out of range
If the reboot doesn't fix that we would need to get an engineer out which I can arrange
Gareth_L
dansaville
  • 6
Message 10 of 13
Re: Slow Speed M200
Sorry I have been away with work for a few days. I have just switched it off for 5 mins and turned back on. From what I can see there is no change.
Dan
