on 30-11-2022 21:44
For several weeks i've been getting pretty poor download speed ~ 20-30Mbps.Ive followed the assistant, but each time I get told to check back after 24 hours to book a technician and after 24 hours the same pop up appears, no option to book a technician.
This evening I ran the Virgin Media speed test and had 120Mbps, but when i rechecked 5 minutes later it was back down to 30Mbps.
I'm on 125Mbps connection.
on 30-11-2022 22:39
on 01-12-2022 17:57
Alessandro,
Thanks for your response.
receive window auto-tuning level: shows normal
on 03-12-2022 16:09
Any further support available on this please?
03-12-2022 18:05 - edited 03-12-2022 18:06
try a new cable
https://www.amazon.co.uk/1aTTack-Ethernet-Network-Double-Shielded/dp/B004WCQB9G/?_encoding=UTF8&pd_r...
what hub do you have?
on 03-12-2022 20:27
It's a Hub 3 in modem mode going to an Asus RT-N66U. Had virgin media for about a year and speeds have pretty much always been on the money until the last month or so.
on 03-12-2022 20:57
Taken Hub 3 out of modem mode. Speed definitely hasn't improved.
Pretty sure I'm below the Minimum Guaranteed Download Speed. I'd like to arrange for an engineer to visit and investigate.
04-12-2022 12:04 - edited 04-12-2022 12:07
test in modem mode without a router connect PC to hub and power off hub for 2 mins
Run a CMD
ping -t 194.168.4.100
on the download test does it spike?
It could be that VM or router past VM network are doing SFQ on a router and some people in your area are downloading with many connections bring the speed down vs HFQ but mean you buffer when you hit the available bandwidth so some thing like HFQ+SFQ would be better but don't think anyone has done.
Test on other speed test sites.
https://speedtest.samknows.com/
https://www.thinkbroadband.com/speedtest
https://www.waveform.com/tools/bufferbloat
on 06-12-2022 12:25
Hey Richini, thank you reaching out and I am sorry you are having some connection issues.
I have taken a look at our side and I can see you have spoke to the team already did they manage to get this resolved for you? Thanks
Matt - Forum Team
New around here?
