Lukeastack
  • 29
Message 1 of 28
Slow Speed 1Gig
Upgraded from 350 to 1Gig, yet the speeds were better when i had the 350? Using Wired i get anywhere between 300-700, Realspeed is currently saying that only 400 is going to the router. Wi-Fi, near or at a distance from the router gets around 20Mbps, (On 2.4) 70-200 on (5.0). Any ideas on the issue, and maybe a fix?
Tags (2)
Anonymous
Not applicable
Message 2 of 28
Re: Slow Speed 1Gig
Could you access your router using http://192.168.0.1/  or http://192.168.100.1/  for modem mode . Don't log in, select the 'Check Router Status' option and paste your 'Downstream', 'Upstream', and 'Network Log' tabs?
At least we can check the stats to rule out an issue with the line.
Lukeastack
  • 29
Message 3 of 28
Re: Slow Speed 1Gig
Every time i do this, i tried it earlier too, nothing happens. It's just a blank white box.
Anonymous
Not applicable
Message 4 of 28
Re: Slow Speed 1Gig
Ah, HUB 4.
I'm unsure if you can access the options following a login instead? (Advanced Settings, Tools, Network Status).
Lukeastack
  • 29
Message 5 of 28
Re: Slow Speed 1Gig
As for Network it dates back to 24/07
14620000041.0205995120 KSym/sec64QAM3
23940000041.0205995120 KSym/sec64QAM4
35370000041.5205995120 KSym/sec64QAM2
46030000042.0205995120 KSym/sec64QAM1
1US_TYPE_STDMA0000
2US_TYPE_STDMA0000
3US_TYPE_STDMA0000
4US_TYPE_STDMA0000
253310000004.59999838.983261QAM25625
81950000005.50000038.605377QAM2568
92030000005.30000338.983261QAM2569
102110000005.09999838.983261QAM25610
112190000004.80000338.983261QAM25611
122270000004.59999838.605377QAM25612
132350000004.40000238.983261QAM25613
142430000003.90000238.605377QAM25614
152510000003.29999938.605377QAM25615
162590000003.09999838.605377QAM25616
172670000003.09999838.983261QAM25617
182750000003.20000138.605377QAM25618
192830000003.50000038.605377QAM25619
202910000003.90000238.605377QAM25620
212990000004.09999838.983261QAM25621
223070000004.30000338.605377QAM25622
233150000004.59999838.983261QAM25623
243230000004.50000038.605377QAM25624
263390000004.50000038.983261QAM25626
273470000004.19999738.983261QAM25627
283550000004.30000338.983261QAM25628
293630000004.30000338.605377QAM25629
303710000004.19999738.983261QAM25630
31
3790000003.79999938.983261QAM256
25Locked000
8Locked151358517100
9Locked162850121200
10Locked163608982900
11Locked152963101800
12Locked152810258400
13Locked163514918000
14Locked164230192700
15Locked152786499400
16Locked153281296200
17Locked163451969900
18Locked163930894200
19Locked152039976000
20Locked141057225200
21Locked161980595300
22Locked162865075400
23Locked151110879300
24Locked210981726100
26Locked212649580100
27Locked193236921700
28Locked192577862800
29Locked205198691700
30Locked206572945800
31Locked141290061200
Lukeastack
  • 29
Message 6 of 28
Re: Slow Speed 1Gig
Fri 24/07/2020 08:39:385MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Fri 24/07/2020 08:39:425RNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Fri 24/07/2020 08:39:496SW Download INIT - Via Config file ;kfoA,.iyewrkldJKDHSUBsgv
Fri 24/07/2020 08:42:345MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Fri 24/07/2020 08:42:344Disruption during SW download - Power Failure
Fri 24/07/2020 08:42:395RNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Fri 24/07/2020 08:42:466SW Download INIT - Via Config file ca69834ncxv9873254k;fg87d
Fri 24/07/2020 08:44:006SW download Successful - Via Config file
Fri 24/07/2020 08:46:325MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Fri 24/07/2020 08:46:533Unicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Fri 24/07/2020 08:46:533No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Fri 24/07/2020 08:46:543Unicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Fri 24/07/2020 08:46:545TCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Fri 24/07/2020 08:47:243Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Fri 24/07/2020 08:54:183SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Fri 24/07/2020 08:54:206CM-STATUS message sent. Event Type Code: 2; Chan ID: 11; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Fri 24/07/2020 08:54:225Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Fri 24/07/2020 08:54:283SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Fri 24/07/2020 08:54:416CM-STATUS message sent. Event Type Code: 5; Chan ID: 25; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Fri 24/07/2020 08:55:263SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Fri 24/07/2020 08:55:266CM-STATUS message sent. Event Type Code: 2; Chan ID: 12; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Fri 24/07/2020 08:55:273SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Fri 24/07/2020 08:55:305Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Fri 24/07/2020 08:56:006CM-STATUS message sent. Event Type Code: 4; Chan ID: 11; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Fri 24/07/2020 08:56:253SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Fri 24/07/2020 08:56:265Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Fri 24/07/2020 08:56:486CM-STATUS message sent. Event Type Code: 5; Chan ID: 8; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Fri 24/07/2020 08:59:093SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Fri 24/07/2020 08:59:145Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Fri 24/07/2020 08:59:523Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Fri 24/07/2020 08:59:543No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Fri 24/07/2020 09:02:185MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Fri 24/07/2020 09:07:053SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Fri 24/07/2020 09:07:085Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Fri 24/07/2020 09:07:186CM-STATUS message sent. Event Type Code: 4; Chan ID: 14; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Fri 24/07/2020 17:12:525MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Lukeastack
  • 29
Message 7 of 28
Re: Slow Speed 1Gig
Still need help with this, a little bit better but samknows saying router is getting 600 ish, now.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 8 of 28
Re: Slow Speed 1Gig
I can see that all the entries bar one are from a half hour period last Friday (24 July) pointing to a lot of negotiating.
You may be as well trying a factory reset on the Hub.
Lukeastack
  • 29
Message 9 of 28
Re: Slow Speed 1Gig
I'll try this next, whats strange is the speed to my computer is higher than that what goes to the router. 9 times out of 10.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 10 of 28
Re: Slow Speed 1Gig
Please explain.
