topaul13
  • 16
Message 1 of 5
Slow M500 Speed
We recently upgraded to the M500 package and we are getting nowhere near the speeds advertised.
My Laptop is currently ethernet CAT6 cable connected and the speed dropped down to 13mbps last night. I think its intermittent to say the least but we have never got close to 500mbps.
I will post the BQM and Router settings in following posts
Thanks in advance for your help.
Tags (1)
topaul13
  • 16
Message 2 of 5
Re: Slow M500 Speed
topaul13
  • 16
Message 3 of 5
Re: Slow M500 Speed
Router status:
1331000000-0.440256 qam25
2267000000040256 qam17
3275000000-0.240256 qam18
4283000000-0.240256 qam19
5291000000040256 qam20
6299000000040256 qam21
7307000000040256 qam22
8315000000040256 qam23
9323000000040256 qam24
10371000000-1.240256 qam26
11379000000-140256 qam27
12387000000-140256 qam28
13395000000-0.740256 qam29
14403000000-0.740256 qam30
15411000000-0.540256 qam31
16419000000-0.540256 qam32
17427000000-0.740256 qam33
18435000000-0.940256 qam34
19443000000-0.940256 qam35
20451000000-0.740256 qam36
21459000000-0.740256 qam37
22467000000-0.940256 qam38
23475000000-1.440256 qam39
24483000000-1.540256 qam40
1Locked40.900
2Locked40.940
3Locked40.950
4Locked40.950
5Locked40.3130
6Locked40.3170
7Locked40.370
8Locked40.390
9Locked40.9180
10Locked40.910
11Locked40.380
12Locked40.970
13Locked40.950
14Locked40.950
15Locked40.3190
16Locked40.3170
17Locked40.9170
18Locked40.3200
19Locked40.9140
20Locked40.9170
21Locked40.990
22Locked40.9110
23Locked40.390
24Locked40.370
topaul13
  • 16
Message 4 of 5
Re: Slow M500 Speed
13260001240.8512064 qam13
23939996641.3512064 qam12
34620005642.8512064 qam11
45370003145.8512064 qam10
3ATDMA0010
4ATDMA0000
topaul13
  • 16
Message 5 of 5
Re: Slow M500 Speed
17/12/2020 14:23:55noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
17/12/2020 14:23:44Warning!LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
17/12/2020 13:53:45criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
17/12/2020 13:44:14noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
17/12/2020 13:43:10Warning!LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
17/12/2020 12:36:57noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
17/12/2020 12:36:6Warning!LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
17/12/2020 07:15:3noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
17/12/2020 07:13:37Warning!LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:01:38criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
16/12/2020 19:43:55noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
16/12/2020 19:39:5Warning!LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
16/12/2020 06:20:41criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/12/2020 17:11:50noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt053-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/12/2020 17:11:50ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/12/2020 15:59:36criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/12/2020 05:11:50noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt053-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/12/2020 05:11:50ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/12/2020 22:33:48criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
07/12/2020 17:11:50noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt053-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
