  • 175
  • 17
Dialled in
Message 1 of 17
Slow M350 download speed
I just did speedtest on a wired connection using my PC and noticed i'm not receiving the speeds I should be getting.
https://www.speedtest.net/result/9004859603
https://www.speedtest.net/result/9000797705
https://www.speedtest.net/result/8996976523
https://www.speedtest.net/result/8996966663
1 395000000 10 38 256 qam 27
2 187000000 12.4 38 256 qam 7
3 195000000 12 38 256 qam 8
4 203000000 11.8 38 256 qam 9
5 211000000 11.4 38 256 qam 10
6 219000000 11.1 38 256 qam 11
7 227000000 11 38 256 qam 12
8 235000000 10.8 38 256 qam 13
9 243000000 10.3 38 256 qam 14
10 251000000 9.5 38 256 qam 15
11 259000000 9 38 256 qam 16
12 267000000 9.4 38 256 qam 17
13 275000000 9.5 38 256 qam 18
14 283000000 9.9 38 256 qam 19
15 291000000 10 38 256 qam 20
16 299000000 10 38 256 qam 21
17 307000000 9.9 40 256 qam 22
18 315000000 10.1 38 256 qam 23
19 323000000 10.1 40 256 qam 24
20 379000000 10 38 256 qam 25
21 387000000 10 38 256 qam 26
22 403000000 9 38 256 qam 28
23 411000000 8.4 38 256 qam 29
24 419000000 8 38 256 qam 30
1 Locked 38.9 16 0
2 Locked 38.9 36 0
3 Locked 38.9 14 0
4 Locked 38.6 14 0
5 Locked 38.9 11 0
6 Locked 38.9 27 0
7 Locked 38.6 22 0
8 Locked 38.6 12 0
9 Locked 38.6 16 0
10 Locked 38.6 17 0
11 Locked 38.6 24 0
12 Locked 38.6 47 0
13 Locked 38.6 34 0
14 Locked 38.9 22 0
15 Locked 38.6 24 0
16 Locked 38.9 15 0
17 Locked 40.3 24 0
18 Locked 38.9 7 0
19 Locked 40.3 23 0
20 Locked 38.6 8 0
21 Locked 38.9 20 0
22 Locked 38.6 16 0
23 Locked 38.9 28 0
24 Locked 38.6 31 0
1 46199971 3.5 5120 64 qam 1
2 25800000 3.4 5120 64 qam 4
3 32600000 3.4 5120 64 qam 3
4 39400004 3.5 5120 64 qam 2
1 ATDMA 0 0 0 0
2 ATDMA 0 0 0 0
3 ATDMA 0 0 0 0
4 ATDMA 0 0 0 0
03/02/2020 10:06:4 Error DHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
31/01/2020 00:06:52 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/01/2020 03:03:16 notice SW download Successful - Via NMS
30/01/2020 03:00:59 notice SW Download INIT - Via NMS
26/01/2020 01:05:19 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
25/01/2020 20:55:32 notice DHCP Renew - lease parameters tftp file-cmreg-vmdg505-rtsxxl35016u-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
25/01/2020 20:55:32 Error DHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
25/01/2020 20:37:12 Error DHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
25/01/2020 19:30:14 notice DHCP Renew - lease parameters tftp file-cmreg-vmdg505-rtsxxl35016u-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
25/01/2020 19:30:14 Error DHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
25/01/2020 19:18:56 Error DHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
25/01/2020 18:37:43 notice DHCP Renew - lease parameters tftp file-cmreg-vmdg505-rtsxxl35016u-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
25/01/2020 18:37:43 Error DHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
25/01/2020 14:47:1 Error DHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
25/01/2020 11:32:37 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
25/01/2020 03:15:4 Error DHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/01/2020 13:58:0 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/01/2020 11:52:30 Error DHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
20/01/2020 03:32:7 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
19/01/2020 19:04:37 notice SW download Successful - Via Config file
  • 4.75K
  • 871
  • 1.26K
Message 2 of 17
Re: Slow M350 download speed
Hello
Many thanks for the stats looking at these, some of your downstream power levels are too high and will need looking at by an engineer, you can either call in on 150 or wait for a forum staff member picks up the post.
Regards Mike
  • 2.56K
  • 152
  • 327
Message 3 of 17
Hi nad223.
Sorry about the problems you've had with the service.
So we can get this sorted I will send a PM to confirm some details & hope to hear back from you soon.
Tom
  • 2.56K
  • 152
  • 327
Message 4 of 17
Hi nad223. I can confirm that since our last exchange there's been no changes. Please keep us posted with how things are after the visit we scheduled & we'll take it from there.
Tom
  • 175
  • 17
Dialled in
Message 5 of 17
hi
the connection has become unstable again it keeps cutting out every few minutes, if there are work planned in the area why aren't letters being sent out for convenience please
thanks
  • 3.57K
  • 215
  • 416
Message 6 of 17
Cheers for popping back @nad223 - sorry that you're having some issues once again with your services.
I have had a quick check of your services from here and at the time of writing, there are no area issues or planned work listed.
I can see that you have rebooted recently which is great - the signal levels from here are looking to be within the parameters we would expect and no errors are showing.
As it's been a few weeks since you last posted, can you post a set of new Network logs for us as you did before so we can see if you're seeing anything different from what we have listed here?
It may also be helpful to set up a free “Broadband Quality Monitor” to continually monitor the state of your connection and record any network dropouts.  It does it 24/7/365 and it keeps a visual record of your connection. If you need any help with that please let us know.
Cheers
Katie - Forum Team
  • 175
  • 17
Dialled in
Message 7 of 17
hi
just done a speed test and noticed the speeds have drastically dropped again
9089871163https://www.speedtest.net/result/9089871163
  • 175
  • 17
Dialled in
Message 8 of 17
27/02/2020 01:39:12 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
26/02/2020 22:03:53 notice DHCP Renew - lease parameters tftp file-cmreg-vmdg505-rtsxxl35016u-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
26/02/2020 22:03:53 Error DHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
26/02/2020 21:44:40 Error DHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
26/02/2020 21:26:36 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
26/02/2020 20:47:15 Error DHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
26/02/2020 19:41:6 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
26/02/2020 11:51:23 Error DHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
26/02/2020 01:43:8 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
26/02/2020 01:38:58 Error DHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
20/02/2020 13:15:59 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
20/02/2020 13:15:59 Warning! B-INIT-RNG Failure - Retries exceeded;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
20/02/2020 13:14:20 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
20/02/2020 13:14:20 critical Unicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
20/02/2020 13:12:52 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
20/02/2020 13:12:52 critical REG RSP not received;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
20/02/2020 13:12:52 Error T6 Timeout and retries exceeded;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
20/02/2020 13:12:0 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
20/02/2020 13:11:59 Warning! B-INIT-RNG Failure - Retries exceeded;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
20/02/2020 13:10:52 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
  • 4.25K
  • 169
  • 233
Message 9 of 17
Hi nad223,
Thank you for your post. I'm sorry for any issues you're having.
I have checked over your account from our side and am unable to see anything that should be affecting your speed.
Can you confirm if you're still having this speed issue?
^Martin
  • 175
  • 17
Dialled in
Message 10 of 17
hi
just done a speed test 4/3/20 at 4:02pm
https://www.speedtest.net/result/9096978411
9096978411
