  • 7
Message 1 of 5
Slow M350 download speed
I just did speedtest by Ookla PING ms25 DOWNLOAD Mbps 38.02 UPLOAD Mbps 34.98. Same was in December. Both wifi and cable connections same speed. I have used two diferent PC, still same.
There is a copy of my Hub’s power levels and network log if it helps. Thank you.
Downstream
141100000012.835256 qam33
223500000015.837256 qam13
324300000015.537256 qam14
425100000015.337256 qam15
525900000015.137256 qam16
626700000015.437256 qam17
727500000014.837256 qam18
82830000001537256 qam19
92910000001537256 qam20
102990000001537256 qam21
1130700000014.637256 qam22
1231500000014.537256 qam23
1332300000014.937256 qam24
1434700000014.436256 qam25
1535500000013.636256 qam26
1636300000013.636256 qam27
1737100000013.536256 qam28
1837900000013.536256 qam29
1938700000012.936256 qam30
2039500000013.336256 qam31
2140300000013.336256 qam32
2241900000012.835256 qam34
2342700000012.635256 qam35
2443500000012.636256 qam36
Upstream
1257999764.175512064 qam4
2326000004.175512064 qam3
3394000244.225512064 qam2
4462000174.35512064 qam1
Network log
18/01/2020 11:48:23ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
19/01/2020 03:50:22criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
19/01/2020 06:54:24ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
19/01/2020 13:16:29ErrorDHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
19/01/2020 13:16:29noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-rtsxxl35016u-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
20/01/2020 09:01:16criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
27/01/2020 10:25:55ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
28/01/2020 01:29:29criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
28/01/2020 02:10:55ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
28/01/2020 15:03:52criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
28/01/2020 15:57:49ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
28/01/2020 17:56:0ErrorDHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
28/01/2020 17:56:0noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-rtsxxl35016u-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/01/2020 01:22:16criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
  • 6.49K
  • 485
  • 856
Hero
Message 2 of 5
Re: Slow M350 download speed
Have you only got 8 Downstream channels?
Mike Robinson
Aircraft Engineer & Computer Based Training and Learning Designer for many of the world's Military Arms.
  • 7
Message 3 of 5
No 24 channels
  • 11.37K
  • 787
  • 1.6K
Message 4 of 5
Your downstreams are too high, you need a tech to reduce those
I work for Virgin Media and my posts are my own opinions
  • 3.88K
  • 234
  • 427
Message 5 of 5
Hi Gvido,
Thank you for reaching out to us and welcome back to our community, I am sorry to see you are suffering with slow speeds at the moment, I have had a look our end and I can see that your downstream power levels are out.
I would like to invite you into a private chat so I can arrange a technician,  I will send you a request shortly, please click on the purple envelope to accept.
Kind regards
Paul.
