Pdmorgx9
  • 24
Message 1 of 27
Slow M350 WiFi
my WiFi speed has dropped from around 275mbps a few weeks ago to between 30 and 70 now. This means my daughter gets about 3mbps in her bedroom. I pay for M350 for the high level. Please can somebody help me get this sorted?
thank you
paul
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 2 of 27
Re: Slow M350 WiFi
What speed do you get at >> speedtest.net << with a direct connection using a Cat 5E/6 or better cable between the Hub in Router Mode and a 1Gbs capable Pc/Mac/Chromebook and no other devices connected ?
Pdmorgx9
  • 24
Message 3 of 27
Re: Slow M350 WiFi
Cat 5E/6 forgive my ignorance but is that my Ethernet cable? So what you’re saying is try the speed wired to my laptop whilst no devices use the Wi-fi? Cheers for the reply Mike
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 4 of 27
Re: Slow M350 WiFi
Cat 5E / 6 is the specification of the ethernet cable.
Yes, if you could test with the laptop using the cable and nothing else connected, Wi-Fi or otherwise.
Pdmorgx9
  • 24
Message 5 of 27
Re: Slow M350 WiFi
I’ve done that. Wired it’s download of about 85, upload of 35. Wireless next to the hub it’s 18 download and 23 upload which even I know isn’t right!
I've checked all the wires are connected correctly coming into the house and the hub. I’ve rebooted the hub no improvements. Is it likely it’s a problem with the broadband coming in to the house? I suppose 85 is quite good but when I usually get over 250 it’s rubbish and as I said before massively affecting the Wi-fi reach around the house. I’ve not moved anything that would have caused it, that’s what’s so frustrating!
 Thanks again for your help.
paul
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 6 of 27
Re: Slow M350 WiFi
Then
Can you please
Pdmorgx9
  • 24
Message 7 of 27
Re: Slow M350 WiFi
My BQM
Pdmorgx9
  • 24
Message 8 of 27
Re: Slow M350 WiFi
Downstream
1331000000-0.540256 qam25
2187000000240256 qam7
31950000001.940256 qam8
42030000001.740256 qam9
52110000001.540256 qam10
62190000001.240256 qam11
72270000001.240256 qam12
8235000000140256 qam13
92430000000.740256 qam14
102510000000.740256 qam15
112590000000.540256 qam16
122670000000.540256 qam17
132750000000.240256 qam18
142830000000.540256 qam19
152910000000.240256 qam20
162990000000.440256 qam21
17307000000040256 qam22
18315000000-0.240256 qam23
19323000000-0.440256 qam24
20339000000-0.540256 qam26
21347000000-0.540256 qam27
22355000000-0.540256 qam28
23363000000-0.740256 qam29
24371000000-140256 qam30
1Locked40.980
2Locked40.9110
3Locked40.970
4Locked40.980
5Locked40.970
6Locked40.360
7Locked40.390
8Locked40.960
9Locked40.980
10Locked40.970
11Locked40.970
12Locked40.960
13Locked40.970
14Locked40.970
15Locked40.9170
16Locked40.370
17Locked40.3200
18Locked40.9240
19Locked40.390
20Locked40.360
21Locked40.350
22Locked40.960
23Locked40.960
24Locked40.960
Pdmorgx9
  • 24
Message 9 of 27
Re: Slow M350 WiFi
13259999840512064 qam5
23939998641512064 qam4
34619999341.5512064 qam3
45369997642.5512064 qam2
Pdmorgx9
  • 24
Message 10 of 27
Re: Slow M350 WiFi
eneral Configuration
Network access
Allowed
Maximum Number of CPEs
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
xv9873254k;fg87dsfd;kfoA,
SFID8540
Max Traffic Rate402500089
Max Traffic Burst42600
Min Traffic Rate0
Primary Upstream Service Flow
SFID8539
Max Traffic Rate38500089
Min Traffic Rate0
Max Concatenated Burst42600
Scheduling TypeBestEffort
