Jimc56
Message 1 of 5
Slow Internet speed
I have just signed up for 500mbs broadband and after checking everything I am only getting a maximum of 48mbs!!
Anyone else got the same issue?
I am in Westcliff on Sea, Southend
conman33158
  • 749
  • 67
  • 98
Superfast
Message 2 of 5
Re: Slow Internet speed
What speed do you get with direct wired connection from PC to router using a Cat 5e cable or better with a 1Gbps Ethernet capable network card?
Andruser
  • 5.53K
  • 970
  • 2.28K
Message 3 of 5
If you're measuring that on a wireless device, that is the most likely cause of the problem.  Usually can be improved by playing with settings.  If it is over ethernet, then it's a cable problem.  Tell us which and we can guide you down the appropriate checks.
Number17
Just joined
Message 4 of 5
This has got to be the worst ISP out there. Switched over from Talk Talk after 3 years after been sold a dream of the 100Mbs internet speed. At the last test, i was getting .9Mbs download and 0.56Mbs upload. How's that possible? No customer service to reach, a useless complaint system, the list is abhorrent failure goes on.
conman33158
  • 749
  • 67
  • 98
Superfast
Message 5 of 5
If you want help please start your own thread 🙂
