Slow Internet Speed - especially late afternoons and evenings
aamnads
I am seeing slowness on my recently upgraded 1Gig fibre service. I have already called in and test state that speeds are all ok but not being reflected at home.
Got 1x Pod and another is on its way and no improvements.
I have disconnected all devices and still seeing issues.
See results here:
https://www.thinkbroadband.com/speedtest/1661988122269919155
Also setup BQM and got the below:
Definetly a issue on ethernet and wifi - can someone help please.
1 REPLY 1
Can you test what speeds VM are delivering to your Hub like this.
____________________________________________________
Connect a 1GB enabled computer/laptop, with up to date drivers, via a NEW and working Cat5e/6a ethernet cable, directly to the Hub which you have put into “modem mode” (https://www.virginmedia.com/help/virgin-media-hub-modem-mode ). This ensures that NO other devices are connected
Test speeds at https://speedtest.samknows.com/ - try on 2 different browsers as Chrome sometimes gives odd results.
If they are still low – boot your device into Windows safe+networking mode - to disable any potentially interfering software - and try again.
There are many posts on here (I have a list of ~30!) where QoS software, anti-virus, unknown/flaky software, old network card drivers, corrupted browsers, bad cables or other connected devices are limiting speeds on tests.
______________________________________________________
Report back what that gets. For examples of why do this... see message 7 in the first thread and 9 in in the second and 3 in the third
https://community.virginmedia.com/t5/Speed/HUB-5-and-IGB-wifi/td-p/5088163
https://community.virginmedia.com/t5/Networking-and-WiFi/Slow-Ethernet-Speed/m-p/5060946#M484321
https://community.virginmedia.com/t5/Speed/Upgrade-from-M600-to-Gig1-no-speed-change-with-Hub-4/td-p...
I do not work for VM. My services: HD TV on VIP (+ Sky Sports & Movies & BT sport), x3 V6 boxes (1 wired, 2 on WiFi) Hub5 in modem mode with Apple Airport Extreme Router +2 Airport Express's. On Volt 350Mbps, Talk Anytime Phone, x2 Mobile SIM only iPhones.
