Juiceloose
  • 15
Message 1 of 26
Slow Internet Speed M200 Package
Hi, I've been on the M200 package for a couple of years and consistently received between 200 and 210 download speed. However, in the last two months it's never risen above 85 and sometimes drops as low as 35.
I have a Superhub 2 which I've powered down and rebooted numerous times but it hasn't resolved the problem. It is currently operating in modem mode but I have also switched it back to router mode and the speed doesn't change. My desktop PC is hard wired with a Cat 5e ethernet cable between Superhub and router and router into PC.
I have run the service status test and it states everything is operating correctly.
Can anybody advise what might be causing such a huge slow down in speed.
Many thanks,
Steve.
Anonymous
Not applicable
Message 2 of 26
Re: Slow Internet Speed M200 Package
Many thanks,
Steve.
Could you access your router using http://192.168.0.1/ or http://192.168.100.1 for modem mode . You shouldn't need log in, select the 'Check Router Status' option and paste your 'Downstream', 'Upstream', and 'Network Log' tabs? Please copy/paste this data as text, split between multiple posts (Sometimes you have to click 'Post' twice due to an error message).
The information above may be in a slightly different section for the older HUBs.
Could you please create a BQM (Broadband Quality Monitor) here, and post the live link?
Juiceloose
  • 15
Message 3 of 26
Hi Carl,
Thank you for your prompt reply. I'll do my best to copy and paste the info you require.
Downstream  DS-1 DS-2 DS-3 DS-4 DS-5 DS-6 DS-7 DS-8
Frequency (Hz)267000000275000000283000000291000000299000000307000000315000000323000000
Lock Status(QAM Lock/FEC Sync/MPEG Lock)LockedLockedLockedLockedLockedLockedLockedLocked
Channel ID1718192021222324
Modulation256QAM256QAM256QAM256QAM256QAM256QAM256QAM256QAM
Symbol Rate (Msym/sec)6.9520006.9520006.9520006.9520006.9520006.9520006.9520006.952000
Interleave DepthI=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
Power Level (dBmV)-1.97-1.91-2.01-2.12-2.22-2.35-2.44-2.55
RxMER (dB)37.3637.9437.3637.3638.2638.2637.9437.94
Pre RS Errors39374367440533663295141523061915
Post RS Errors224523682566104015784461044452
Juiceloose
  • 15
Message 4 of 26
Carl,
Apologies if this isn't in the format you require. I'm not sure how to paste it so it is more legible to you.
Steve.
Upstream
US-1 US-2 US-3 US-4
Channel Type 2.0 2.0 2.0 2.0
Channel ID 12 9 10 11
Frequency (Hz) 25800000 46200000 39400000 32600000
Ranging Status Success Success Success Success
Modulation 64QAM 64QAM 64QAM 64QAM
Symbol Rate (Sym/sec) 5120000 5120000 5120000 5120000
Mini-Slot Size 2 2 2 2
Power Level (dBmV) 40.75 42.75 42.75 42.25
T1 Timeouts 0 0 0 0
T2 Timeouts 0 0 0 0
T3 Timeouts 0 0 0 0
T4 Timeouts 0 0 0 0
Juiceloose
  • 15
Message 5 of 26
First TimeLast TimePriorityError NumberDescription
22/11/2020 16:27:57 GMT22/11/2020 16:27:57 GMTError (4)68000407TOD established
Time Not EstablishedTime Not EstablishedNotice (6)84000510Downstream Locked Successfully
22/11/2020 15:55:13 GMT22/11/2020 15:55:13 GMTError (4)68000407TOD established
Time Not EstablishedTime Not EstablishedCritical (3)82000200No Ranging Response received - T3 time-out
22/11/2020 15:51:44 GMT22/11/2020 15:51:44 GMTWarning (5)66050310Auth Success - Web login successful.
22/11/2020 15:48:46 GMT22/11/2020 15:48:46 GMTWarning (5)66050310Auth Success - Web login successful.
22/11/2020 15:48:15 GMT22/11/2020 15:48:15 GMTError (4)68010302DHCP WAN IP - 86.27.234.183
22/11/2020 15:47:11 GMT22/11/2020 15:47:11 GMTError (4)68000407TOD established
22/11/2020 15:41:25 GMT22/11/2020 15:41:25 GMTWarning (5)66050300Auth Fail - Web login failed.
22/11/2020 15:39:15 GMT22/11/2020 15:39:15 GMTError (4)68000407TOD established
22/11/2020 15:37:19 GMT22/11/2020 15:37:19 GMTNotice (6)84000510Downstream Locked Successfully
Anonymous
Not applicable
Message 6 of 26
The stats don't look too bad to be honest, several errors in the network log, however.
Could you create the BQM when you get chance as this will show if there is an issue with your line, most probably congestion/oversubscription in your area.
Juiceloose
  • 15
Message 7 of 26
Carl,
I've never used BQM before so am not sure if I have correctly done what you asked for.
https://www.thinkbroadband.com/broadband/monitoring/quality/share/37faca9aea749e8ff2d9c4e3b3f07f6a72a0f8fc-22-11-2020
Steve.
Juiceloose
  • 15
Message 8 of 26
Carl,
You might be correct about oversubscription as there have been two new housing estates built in the last 18 months.
Steve.
Anonymous
Not applicable
Message 9 of 26
@Juiceloose wrote:
Carl,
Steve.
The link is correct, however it's showing full red which normally means pinging is disabled.
If you are using your third party router could you enable a ping response?
Juiceloose
  • 15
Message 10 of 26
Carl,
Apologies again. Any ideas how I enable a PIng response. If it's any help it's an Orbi RB50. If not, I can switch Superhub back into router mode and rerun the test.
Steve.
