Recoil13
  • 5
Message 1 of 5
Slow/Intermittent Connectivity
Hello,
Today my internet has been both slow and intermittent - particularly with the upload. I've reset my router multiple times, which hasn't really helped much at all. The light on the Hub 3 is yellow, which I'm sure used to be white (I'm not sure if that's an indicator for anything at all!).
See below for current router status - any help would be much appreciated!
01/01/1970 00:03:24criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:02:44criticalDHCP FAILED - Discover sent, no offer received;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/01/2021 15:10:25criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/01/2021 15:09:40noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/01/2021 14:57:53criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/01/2021 14:57:43noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/01/2021 14:50:51criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/01/2021 14:50:8criticalDHCP FAILED - Discover sent, no offer received;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/01/2021 14:48:25criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/01/2021 14:47:55criticalREG RSP not received;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/01/2021 14:47:55ErrorT6 Timeout and retries exceeded;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:03:29criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:02:48criticalDHCP FAILED - Discover sent, no offer received;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/01/2021 14:42:9criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/01/2021 14:41:14noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/01/2021 13:53:13criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/01/2021 21:16:16ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
09/01/2021 07:56:11criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/01/2021 00:04:30noticeSW download Successful - Via NMS
08/01/2021 00:02:52noticeSW Download INIT - Via NMS
1323000000738256 qam24
22030000007.538256 qam9
32110000007.438256 qam10
42190000007.338256 qam11
5227000000738256 qam12
62350000006.938256 qam13
72430000006.538256 qam14
82510000006.638256 qam15
92590000006.538256 qam16
102670000006.638256 qam17
112750000006.838256 qam18
12283000000738256 qam19
13291000000738256 qam20
142990000007.338256 qam21
15307000000738256 qam22
16315000000738256 qam23
17331000000738256 qam25
183390000007.138256 qam26
19347000000738256 qam27
20355000000738256 qam28
213630000006.938256 qam29
223710000006.838256 qam30
233790000006.838256 qam31
243870000006.638256 qam32
1Locked38.980
2Locked38.950
3Locked38.940
4Locked38.960
5Locked38.960
6Locked38.960
7Locked38.970
8Locked38.960
9Locked38.960
10Locked38.650
11Locked38.960
12Locked38.960
13Locked38.950
14Locked38.670
15Locked38.970
16Locked38.960
17Locked38.960
18Locked38.950
19Locked38.960
20Locked38.690
21Locked38.650
22Locked38.640
23Locked38.650
24Locked38.900
Recoil13
  • 5
Message 2 of 5
Re: Slow/Intermittent Connectivity
15369976947.3512016 qam6
26029908147.5512016 qam5
34619930247512016 qam7
43939929146.5512016 qam8
1ATDMA0040
2ATDMA0040
3ATDMA0000
4ATDMA0010
General Configuration
Network access
Allowed
Maximum Number of CPEs
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
cmreg-vmdg505-bbt062-b.cm
SFID2451964
Max Traffic Rate402500089
Max Traffic Burst42600
Min Traffic Rate0
Primary Upstream Service Flow
SFID2451963
Max Traffic Rate38500089
Min Traffic Rate0
Max Concatenated Burst42600
Scheduling TypeBestEffort
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.93K
Message 3 of 5
Recoil13
  • 5
Message 4 of 5
Ah yeah, sorry I started that too and forgot to add it!
My BQM
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.93K
Message 5 of 5
Your >> BQM << will need to run until about 16:00 16/1/2021 to get any kind of picture showing, please leave it running.
