Stumbler
  • 164
  • 33
Superfast
Message 1 of 48
Slow Gig 1 broadband...........again
Having read scage 's trial and tribulations, whose patience and resilience I admire, it is with some trepidation that I make an almost identical post.
Since upgrading from M600, which gave me a reliable 660mb download, I upgraded to Giganet and a Hub4 and can now manage only 400+mb on a good day.
At the moment, I'm on my 3rd Hub4 and have had three engineers, all doing their best, but without success.
Samknows Real Speed Test shows the Hub receiving 1100/52. Even with a laptop, connected with a cat8 cable as the only device, I can barely obtain a 500mb download speed.
This does seem to be a bit of a regular theme here, so if any learned folks have any thoughts, I'd love to hear them.
Stumbler
  • 164
  • 33
Superfast
Message 2 of 48
Re: Slow Giganet...........again
Router status
Cable Modem Status
Cable Modem Status
Online
DOCSIS 3.1
Primary downstream channel
Locked
SC-QAM
DOCSIS 3.0 channels
31
4
DOCSIS 3.1 channels
1
0
3.0 Downstream channels
253307500003.339QAM25625
61787500002.339QAM2566
71867500002.539QAM2567
81947500002.638.6QAM2568
92027500002.839QAM2569
102107500002.639QAM25610
112187500002.740.4QAM25611
122267500002.639QAM25612
132347500002.539QAM25613
142427500002.439QAM25614
152507500002.238.6QAM25615
162587500002.139QAM25616
172667500001.839QAM25617
18274750000239QAM25618
192827500002.639QAM25619
20290750000339QAM25620
212987500003.638.6QAM25621
223067500003.839QAM25622
233147500003.939QAM25623
243227500003.539QAM25624
263387500003.839QAM25626
273467500003.739QAM25627
283547500003.739QAM25628
293627500003.539QAM25629
303707500003.738.6QAM25630
313787500003.539QAM25631
323867500003.539QAM25632
333947500003.238.6QAM25633
34402750000338.6QAM25634
35410750000340.4QAM25635
364187500002.939QAM25636
25Locked38.98326100
6Locked38.98326100
7Locked38.98326100
8Locked38.60537700
9Locked38.98326100
10Locked38.98326100
11Locked40.36628700
12Locked38.98326100
13Locked38.98326100
14Locked38.98326100
15Locked38.60537700
16Locked38.98326100
17Locked38.98326100
18Locked38.98326100
19Locked38.98326100
20Locked38.98326100
21Locked38.60537700
22Locked38.98326100
23Locked38.98326100
24Locked38.98326100
26Locked38.98326100
27Locked38.98326100
28Locked38.98326100
29Locked38.98326100
30Locked38.60537700
31Locked38.98326100
32Locked38.98326100
33Locked38.60537700
34Locked38.60537700
35Locked40.36628700
36Locked38.98326100
Stumbler
  • 164
  • 33
Superfast
Message 3 of 48
3.1 Downstream channels
37944K1840QAM4096424
37Locked412.81838314410
3.0 Upstream channels
153700000445120 KSym/sec64QAM1
24620000043.35120 KSym/sec64QAM2
332600000445120 KSym/sec64QAM4
43940000043.85120 KSym/sec64QAM3
1US_TYPE_STDMA0010
2US_TYPE_STDMA0000
3US_TYPE_STDMA0000
4US_TYPE_STDMA0000
General Configuration
Network access
true
Maximum Number of CPEs
1
Baseline Privacy
true
DOCSIS Mode
3.1
Config file
cmreg-vmdg640-bbt076-b.cm
SFID
59256
Max Traffic Rate
1230000450
Max Traffic Burst
42600
Min Traffic Rate
0
Primary Upstream Service Flow
SFID
59255
Max Traffic Rate
55000270
Max Traffic Burst
42600
Min Traffic Rate
0
Max Concatenated Burst
42600
Scheduling Type
bestEffort
1US_TYPE_STDMA0010
2US_TYPE_STDMA0000
3US_TYPE_STDMA0000
4US_TYPE_STDMA0000
Network access
true
1
Baseline Privacy
true
DOCSIS Mode
3.1
Config file
SFID
59256
Max Traffic Rate
1230000450
Max Traffic Burst
42600
Min Traffic Rate
0
SFID
59255
Max Traffic Rate
55000270
Max Traffic Burst
42600
Min Traffic Rate
0
42600
Scheduling Type
bestEffort
Sat 12/02/2022 09:17:086SW Download INIT - Via Config file cmreg-vmdg640-bbt076-b.cm
Sat 12/02/2022 09:18:226SW download Successful - Via Config file
Sat 12/02/2022 09:20:575MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sat 12/02/2022 09:48:434DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Thu 01/01/1970 00:01:203No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sat 12/02/2022 10:15:515MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sat 12/02/2022 11:01:114DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Stumbler
  • 164
  • 33
Superfast
Message 4 of 48
  • 6.81K
  • 592
  • 1.78K
Message 5 of 48
Okay stats are all fine.  Can you setup and share a BQM please?   www.thinkbroadband.com/ping
Also if you are using a Windows device, can you test with a wired connection using "Safe Mode with Networking support"
As for the Cat 8 cable, that's a bit overkill and sometimes the shielding on these cables can affect the connection in the ethernet ports.  Best to stick to a Cat 6a or even a Cat 5e, both are quite capable of Gigabit speeds.
Stumbler
  • 164
  • 33
Superfast
Message 6 of 48
Thanks for your response, Adduxi
I set up a BQM a few days ago:-
BQM Link
The poor speeds that I've experienced are mainly via a Windows 11 desktop, which was previously getting 660+mb on M600, before I upgraded. So, dropping back to 300mb is disappointing.
I've tried safe mode with networking, as well as wiring up a Windows 10 laptop as the only device attached to the hub, to no avail. Samknows suggests 1100mb to the router but <300mb to the PC.
  • 6.81K
  • 592
  • 1.78K
Message 7 of 48
@Stumbler wrote:
<snip>   a Windows 10 laptop as the only device attached to the hub, to no avail. Samknows suggests 1100mb to the router but <300mb to the PC.  John
There is the issue, VM will acknowledge full speed to the Hub.  Not too sure where you will go from here?  If you have a good Cat 6a cable and wired directly to the Hub, there is not much else you can test with.  Strange .....
BTW, the BQM link is not working, I suspect your WAN IP is incorrect ?
Stumbler
  • 164
  • 33
Superfast
Message 8 of 48
@Adduxi, thanks for your time on this.
Not sure what happened to the BQM link, but here is a snapshot from Sunday :-
VM's problem management is a disgrace really. They are quick to send an engineer. And, even quicker to close the problem record (if there is one!), whether the issue is resolved or not!
Thanks again.
Stumbler
  • 164
  • 33
Superfast
Message 9 of 48
Another six weeks have passed and my speeds are yet to improve. If I can hit 250mb download, it's a good day.
I just can't believe that I've gone from the M600 package, reaching speeds of 660mb, to the Gigabit package and getting more than 25%.
My hardware and infrastructure haven't changed. It's just the Hub and the the upgraded package.
So far, I have had three hubs since the upgrade.............
I'm an East End lad, born and bred, so I'm starting to wonder whether "Gigabit" is rhyming slang!
Help!!!!!!!!!!!!!
  • 35.1K
  • 3.41K
  • 6.68K
Message 10 of 48
Can you humour me and do the speed test exactly like this...
___________________________________________________
Connect a 1GB enabled computer/laptop, with up to date drivers, via a NEW and working Cat5e/6a ethernet cable, directly to the Hub which you have put into “modem mode”
(https://www.virginmedia.com/help/virgin-media-hub-modem-mode ).
This ensures that NO other devices can be connected
Test speeds at https://speedtest.samknows.com/ - try on 2 different browsers.
If they are still low – boot your device into Windows safe+networking mode - to disable any potentially interfering software - and try again.
There are many posts on here (I have a list of ~30!) where QoS software, unknown/flaky software, old network card drivers, corrupted browsers, bad cables or other connected devices are limiting speeds on tests.
Report back what that gets.
