Austenlong21
  • 7
Message 1 of 12
Slow Download/Upload Speed
I'm paying for 100mbs and I'm currently recieving between 1.5mbs - 10mbs and this is affecting downloads from various devices within my home. I'm attempting to download them all at seperate times during off peak hours as well to compare speeds but it isnt looking good. I'm using LAN for both my desktop & PS5.
Here are my stats from checking my router status:
Downstream bonded channelsChannel Frequency (Hz) Power (dBmV) SNR (dB) Modulation Channel ID
1235000000540256 qam13
21390000007.540256 qam1
31470000007.540256 qam2
41550000007.440256 qam3
51630000007.440256 qam4
61710000007.140256 qam5
71790000006.840256 qam6
81870000006.540256 qam7
91950000006.440256 qam8
10203000000640256 qam9
112110000005.840256 qam10
122190000005.540256 qam11
132270000005.340256 qam12
142430000004.440256 qam14
152510000004.440256 qam15
162590000004.640256 qam16
172670000005.440256 qam17
182750000005.940256 qam18
192830000006.340256 qam19
202910000006.140256 qam20
212990000006.440256 qam21
223070000006.340256 qam22
233150000006.540256 qam23
243230000006.840256 qam24
  Upstream bonded channelsChannel Frequency (Hz) Power (dBmV) Symbol Rate (ksps) Modulation Channel ID
13259998639512064 qam13
23940001739512064 qam12
34620000039512064 qam11
45369998140.5512064 qam10
General Configuration
Network access
Allowed
Maximum Number of CPEs
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
873254k;fg87dsfd;kfoA,.iy
SFID154
Max Traffic Rate117000047
Max Traffic Burst42600
Min Traffic Rate0
Primary Upstream Service Flow
SFID153
Max Traffic Rate10500047
Max Traffic Burst16320
Min Traffic Rate0
Max Concatenated Burst16320
Scheduling Type
BestEffort
Network LogTime Priority Description
21/11/2020 22:49:50criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/11/2020 09:49:28noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/11/2020 09:22:31criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/11/2020 08:46:24Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/11/2020 05:56:10noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
20/11/2020 21:47:18Warning!LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
20/11/2020 05:50:24Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
20/11/2020 05:50:24criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
20/11/2020 05:50:20Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
20/11/2020 05:50:20criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
20/11/2020 03:08:59Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
20/11/2020 03:08:59criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
20/11/2020 03:08:57Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
20/11/2020 03:08:57criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
20/11/2020 03:08:54Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
20/11/2020 03:08:54criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
20/11/2020 03:08:53criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
18/11/2020 16:25:54criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
18/11/2020 09:04:46noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt057-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 2 of 12
Re: Slow Download/Upload Speed
Can you post the second table from the Downstream & Upstream tabs please.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 3 of 12
What speeds do you get at >> speedtest.net << with a direct connection using a Cat 5E or better cable between the Hub in Router Mode and a 1Gbs capable Pc/Mac/Chromebook and no other devices connected ?
Austenlong21
  • 7
Message 4 of 12
Downstream bonded channels Channel Locked Status RxMER (dB) Pre RS Errors Post RS Errors 1 Locked 40.3 15 0 2 Locked 40.9 5 0 3 Locked 40.9 23 0 4 Locked 40.3 27 0 5 Locked 40.3 11 0 6 Locked 40.3 7 0 7 Locked 40.3 9 0 8 Locked 40.3 27 0 9 Locked 40.3 26 0 10 Locked 40.3 10 0 11 Locked 40.9 7 0 12 Locked 40.9 15 0 13 Locked 40.9 11 0 14 Locked 40.3 24 0 15 Locked 40.3 16 0 16 Locked 38.9 15 0 17 Locked 40.3 16 0 18 Locked 40.3 11 0 19 Locked 40.3 9 0 20 Locked 40.3 13 0 21 Locked 40.3 14 0 22 Locked 40.9 12 0 23 Locked 40.3 14 0 24 Locked 40.3 13 0 Upstream bonded channels Channel Channel Type T1 Timeouts T2 Timeouts T3 Timeouts T4 Timeouts 1 ATDMA 0 0 0 0 2 ATDMA 0 0 1 0 3 ATDMA 0 0 0 0 4 ATDMA 0 0 0 0
Austenlong21
  • 7
Message 5 of 12
1Locked40.3150
2Locked40.950
3Locked40.9230
4Locked40.3270
5Locked40.3110
6Locked40.370
7Locked40.390
8Locked40.3270
9Locked40.3260
10Locked40.3100
11Locked40.970
12Locked40.9150
13Locked40.9110
14Locked40.3240
15Locked40.3160
16Locked38.9150
17Locked40.3160
18Locked40.3110
19Locked40.390
20Locked40.3130
21Locked40.3140
22Locked40.9120
23Locked40.3140
24Locked40.3130
2ATDMA0010
3ATDMA0000
4ATDMA0000
Austenlong21
  • 7
Message 6 of 12
This is what I get when I test my speed VIA PC connect through TP-Link powerlines. I'm using A Cat5e ethernet cable on both ends.
Austenlong21
  • 7
Message 7 of 12
I also have at max 7 connected devices. These are:
Desktop (on for the majority of the time due to work related tasks)
2 x Laptop (Used at various times during the day/night)
3 x Mobile Phone (only 1 connected all day due to being the only one on furlough)
PS5 Games Console (Just bought it and unable to use it properly due to low download speeds)
Chromecast (Used to watch TV etc)
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 8 of 12
Austenlong21
  • 7
Message 9 of 12
With only my Desktop connected I am recieving 10.06mbps Download and 5.97mbps Upload with a ping of 62ms.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 10 of 12
