Shuyin
  • 11
Message 1 of 5
Slow Download Speed
Hi, I have VM350 and past 3 day my speeds been shockingly slow had i had thinkbroadband.com to monitor my speed for another reason a few months ago and when i looked its all red and all packets were lost.
  • 26.46K
  • 2.7K
  • 4.9K
Message 2 of 5
Re: Slow Download Speed
Post up your Hub stats and the link to your "share live graph" BQM
Shuyin
  • 11
Message 3 of 5
1 330750000 4.5 40 256 qam 25
2 266750000 4.8 40 256 qam 17
3 274750000 4.5 40 256 qam 18
4 282750000 4.5 40 256 qam 19
5 290750000 4.6 40 256 qam 20
6 298750000 4.6 40 256 qam 21
7 306750000 4.5 40 256 qam 22
8 314750000 4.5 40 256 qam 23
9 322750000 4.4 40 256 qam 24
10 370750000 4.4 40 256 qam 26
11 378750000 4.1 40 256 qam 27
12 386750000 4.1 40 256 qam 28
13 394750000 4.1 40 256 qam 29
14 402750000 3.9 40 256 qam 30
15 410750000 4.1 40 256 qam 31
16 418750000 3.7 40 256 qam 32
17 426750000 3.7 40 256 qam 33
18 434750000 3.5 40 256 qam 34
19 442750000 3 40 256 qam 35
20 450750000 3.2 40 256 qam 36
21 458750000 3 40 256 qam 37
22 466750000 2.5 40 256 qam 38
23 474750000 2.7 40 256 qam 39
24 482750000 2.5 40 256 qam 40
1 Locked 40.9 3517493 2704
2 Locked 40.9 -1959047836 239105018
3 Locked 40.9 -1850337050 57545342
4 Locked 40.3 159536841 112183806
5 Locked 40.3 1633126278 16110184
6 Locked 40.9 751681162 3460077
7 Locked 40.9 114695683 291663
8 Locked 40.3 92429608 3153
9 Locked 40.9 55319705 3917
10 Locked 40.9 9805466 1968
11 Locked 40.3 10127579 1722
12 Locked 40.3 29673667 1999
13 Locked 40.3 8324957 2982
14 Locked 40.9 1710536 1901
15 Locked 40.9 998374 15599
16 Locked 40.3 2365021 1035
17 Locked 40.3 5526564 944
18 Locked 40.9 5122262 35272
19 Locked 40.3 2812922 2930
20 Locked 40.9 4013087 1670
21 Locked 40.3 2637250 776
22 Locked 40.9 1651379 1692
23 Locked 40.9 778141 3310
24 Locked 40.9 747735 47671
1 53700000 41.7 5120 64 qam 2
2 39400000 39.8 5120 64 qam 4
3 46200000 40.5 5120 64 qam 3
4 60300000 42 5120 64 qam 1
1 ATDMA 0 0 4 0
2 ATDMA 0 0 8 0
3 ATDMA 0 0 8 0
4 ATDMA 0 0 5 0
19/12/2020 10:18:12 notice LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
19/12/2020 06:48:7 notice DHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt062-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
19/12/2020 06:48:7 Error DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
18/12/2020 22:25:58 Warning! Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
18/12/2020 22:25:52 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
18/12/2020 21:15:49 Warning! Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
18/12/2020 21:10:43 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
18/12/2020 20:54:30 notice LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
18/12/2020 20:54:18 Warning! LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
18/12/2020 15:46:50 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
18/12/2020 08:24:41 Warning! Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
18/12/2020 08:14:48 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
17/12/2020 21:27:34 Warning! Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
17/12/2020 21:26:57 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
17/12/2020 21:24:52 Warning! Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
17/12/2020 21:24:38 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
17/12/2020 21:24:14 Warning! Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
17/12/2020 21:24:13 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
17/12/2020 21:24:12 Warning! Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
17/12/2020 21:24:12 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
0d1fb0951ca8df53c14fcab12cdfcc10f772f89c
  • 26.46K
  • 2.7K
  • 4.9K
Message 4 of 5
Stats are dreadful and the BQM isnt working - are you in modem mode by any chance - if not your i.p. address may have changed - it does occasionally. Check what yours is now and then see if it matches the one you put in the BQM settings.
Then start from a clean sheet...
First switch the Hub off for 5 minutes AND unplug it from the mains. Whilst it's off, do a quick check that all of your coax cable connections are in nice and "finger" tight - at the Hub and wall box and also at any connectors etc. Ensure there are no “unterminated cable loose ends. Disconnect all the connections and reconnect to be sure. Also check that the internal wiring is ok with no kinking or chaffing, check that all looks good with the outside cabling and wall box. Then switch it on again and leave 5 minutes
Then do a Hub “pinhole reset” - make sure the 2 passwords on the Hub sticker are still there and legible first ! Disconnect any ethernet cables from the Hub, and then with the Hub still "switched on" throughout, press pin in firmly with paper clip/SIM tray tool or similar "thin thing" and hold it firmly for at least 60 seconds, release the pin, leave for 10’ to stabilise - dont manually switch it off at any time.
See if anything improves.
When done, check back in the settings and ensure that the RS error counts have all reset to 0. Then check every hour or two for the next day or two to see if they start reappearing - they shouldn't. If they do (particularly the postRS ones) you have a problem (noise) that only a Tech visit will sort.
Shuyin
  • 11
Message 5 of 5
Hello sorry for long time between reply but my IP did change pin-reset worked.
But i am still getting errors
26/12/2020 14:22:43 notice LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
26/12/2020 14:22:7 Warning! LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
26/12/2020 10:14:53 notice DHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt062-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
26/12/2020 10:14:53 Error DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
23/12/2020 05:37:4 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
23/12/2020 00:41:42 notice DHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt062-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
23/12/2020 00:41:42 Error DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/12/2020 20:10:30 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
19/12/2020 21:14:23 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
19/12/2020 18:15:27 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
19/12/2020 18:12:57 notice LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
19/12/2020 18:10:29 Warning! Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
19/12/2020 18:10:21 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
19/12/2020 18:09:51 Warning! Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
19/12/2020 18:09:19 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
19/12/2020 17:32:57 Warning! Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
19/12/2020 17:32:40 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
19/12/2020 17:32:1 Warning! Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
19/12/2020 17:31:54 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
19/12/2020 17:29:1 Warning! Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
1 Locked 40.3 864 204
2 Locked 40.3 4799 341
3 Locked 40.9 3926 301
4 Locked 40.9 3157 263
5 Locked 40.9 2895 273
6 Locked 40.3 2318 232
7 Locked 40.9 1842 201
8 Locked 40.3 1463 192
9 Locked 40.9 1258 168
10 Locked 40.3 386 156
11 Locked 40.9 350 213
12 Locked 40.9 306 178
13 Locked 40.9 303 108
14 Locked 40.3 275 165
15 Locked 40.3 252 189
16 Locked 40.3 251 240
17 Locked 40.9 245 163
18 Locked 40.9 199 187
19 Locked 40.3 211 153
20 Locked 40.9 179 160
21 Locked 40.3 215 170
22 Locked 40.3 260 203
23 Locked 40.9 177 207
24 Locked 40.3 181 153
