huds80
Slow Download Speed on M350
Hi. I wonder if someone can shed any light on some slow speeds I am having. Been getting a solid 350MB for ages. Then yesterday I noticed some slow down, speed tests have been putting my connection at about 10MB down (still the full 35MB up though).
I have isolated all the devices from my nextwork, rebooted the router, reset the router, even went into modem mode with one laptop connected, still the same slow speeds. The call center say everything is fine their end and its my home network?? Can anyone help? I need to be able to work from home!
My network log:
18/12/2020 12:36:8Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
18/12/2020 12:36:3noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
18/12/2020 11:09:13Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
18/12/2020 11:06:15noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
18/12/2020 10:51:37Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:01:42criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
Upstream:
13260000047.8512064 qam11
23940000048512064 qam8
34620000048.5512064 qam7
42580000047.5512064 qam12
3ATDMA0000
4ATDMA0000
Downstream:
13310000002.540256 qam25
22510000001.240256 qam15
32590000001.740256 qam16
4267000000240256 qam17
5275000000240256 qam18
62830000001.740256 qam19
72910000001.540256 qam0
82990000001.540256 qam21
93070000001.540256 qam22
103150000001.940256 qam23
113230000002.240256 qam24
123710000001.440256 qam26
13379000000140256 qam27
14387000000140256 qam28
15395000000140256 qam29
16403000000140256 qam30
174110000000.540256 qam31
184190000000.440256 qam32
19427000000040256 qam33
20435000000-0.240256 qam34
21443000000040256 qam35
22451000000-0.240256 qam36
23459000000040256 qam37
24467000000-0.240256 qam38
1Locked40.320
2Locked40.3160
3Locked40.370
4Locked40.360
5Locked40.950
6Locked40.350
7Locked40.370
8Locked40.9180
9Locked40.970
10Locked40.380
11Locked40.980
12Locked40.310
13Locked40.380
14Locked40.390
15Locked40.3220
16Locked40.3100
17Locked40.3160
18Locked40.390
19Locked40.340
20Locked40.3130
21Locked40.3170
22Locked40.3200
23Locked40.9120
24Locked40.313
0
Tags (4)
  • 26.46K
  • 2.7K
  • 4.9K
Re: Slow Download Speed on M350
All the stats look in order. Can you try the reset again as it can be tricky and the VM website instructions are "wrong" - do it this way.
With the Hub switched "on", disconnect any ethernet connections and then push in the “reset pin” with the end of a paperclip/thin nail/SIM tray “tool” or similar (bigger items like ball point pen ends may not press it in far enough) until you feel it at the “stop point” and hold it there firmly for a "timed" minimum of 60 seconds do NOT manually restart the Hub at any time. Leave it 10' or so to stabilise and then your passwords/passphrase for both the Hub settings and the Wifi networks will revert to the two printed on the Hub sticker on its base/side/card. Make sure you use the wifi one for devices connecting to the wifi and the settings/admin one to access the Hub (it is a six digit numeric one).
See if that sorts it first.
