MrT73
  • 7
Message 1 of 9
Slow Download Internet Speed that geetting Worse and Well below Guaranteed
I have Superhub 4 and on M350.
I get now around 59 to 70 Mbs, and that is testing with the laptop connected directly to the Superhub 4 over cat 6 cable.  The upload is fine and to be honest, is usually just about the 35Mbps at around 36Mbps.  I run the tests at various times of the day and certainly not getting anything close to Guaranteed 181 Mbps.
Here details from my Superhub4
3.0 Downstream channels
30371000000-2.239QAM25630
1139000000-0.639QAM2561
2147000000-1.139QAM2562
3155000000-1.539QAM2563
4163000000-1.839QAM2564
5171000000-2.139QAM2565
6179000000-2.239QAM2566
7187000000-2.339QAM2567
8195000000-2.339QAM2568
9203000000-2.638.6QAM2569
10211000000-2.939QAM25610
11219000000-2.939QAM25611
12227000000-2.939QAM25612
13235000000-2.939QAM25613
14243000000-3.139QAM25614
15251000000-3.239QAM25615
16259000000-3.139QAM25616
17267000000-2.838.6QAM25617
18275000000-2.439QAM25618
19283000000-2.639QAM25619
20291000000-2.739QAM25620
21299000000-3.239QAM25621
22307000000-3.439QAM25622
23315000000-3.138.6QAM25623
24323000000-1.938.6QAM25624
25331000000-1.338.6QAM25625
26339000000-1.240.4QAM25626
27347000000-1.439QAM25627
28355000000-1.838.6QAM25628
29363000000-239QAM25629
31379000000-2.538.6QAM256
31
30Locked38.98326100
1Locked38.98326100
2Locked38.98326100
3Locked38.98326100
4Locked38.98326100
5Locked38.98326100
6Locked38.98326100
7Locked38.98326100
8Locked38.98326100
9Locked38.60537700
10Locked38.98326100
11Locked38.98326100
12Locked38.98326100
13Locked38.98326100
14Locked38.98326100
15Locked38.98326100
16Locked38.98326100
17Locked38.60537700
18Locked38.98326100
19Locked38.98326100
20Locked38.98326100
21Locked38.98326100
22Locked38.98326100
23Locked38.60537700
24Locked38.60537700
25Locked38.60537700
26Locked40.36628700
27Locked38.98326100
28Locked38.60537700
29Locked38.98326100
31Locked38.60537700
3.1 Downstream channelsChannel Channel Width (MHz) FFT Type Number of Active Subcarriers Modulation (Active Profile) First Active Subcarrier (Hz)
159804K1560QAM4096392
3.1 Downstream channelsChannel ID Lock Status RxMER Data (dB) PLC Power (dBmV) Correcteds (Active Profile) Uncorrectables (Active Profile)
159Locked42-1.22011400
0
Tags (1)
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 2 of 9
Re: Slow Download Internet Speed that geetting Worse and Well below Guaranteed
Please post the data from the the Upstream, Configuration and Network Log tabs onto here, if you get a yellow / straw box warning click the Post button again.
Use one post for each tab if you wish.
Please do not use screen shots.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 3 of 9
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 4 of 9
What speeds do you get at >>  SamKnows << with a direct connection using a Cat 5E or better ethernet cable between the Hub in Router Mode and a 1Gbs capable Pc/Mac/Chromebook and no other devices connected ?
Then immediately after …
Can you Login to the Hub Settings and navigate to the Connected Devices page - what is the reported 'connection speed’ for the ethernet cable connected device you used for the speed test ?
MrT73
  • 7
Message 5 of 9
3.0 Upstream channels Channel Frequency (Hz) Power (dBmV) Symbol Rate (ksps) Modulation Channel ID
146200000535120 KSym/sec64QAM1
22580000051.85120 KSym/sec64QAM4
33260000052.35120 KSym/sec64QAM3
43940000052.85120 KSym/sec64QAM2
3.0 Upstream channels Channel Channel Type T1 Timeouts T2 Timeouts T3 Timeouts T4 Timeouts
1US_TYPE_STDMA0000
2US_TYPE_STDMA0000
3US_TYPE_STDMA0000
4US_TYPE_STDMA0000
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 6 of 9
Your Upstream Power Levels are all too high.
This will need an engineer to put right.
You can either call in (08:00 is the best time) or wait on here for a few days (6 to 10 days average) until one of the VM Forum Staff comes along.
MrT73
  • 7
Message 7 of 9
BQM Direct Link
https://www.thinkbroadband.com/broadband/monitoring/quality/share/b4dac7dc801c1c87cfab049ff39e045420a67a74
MrT73
  • 7
Message 8 of 9
Thanks for the update, what should the upstream power levels be?
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 9 of 9
Ideally around 45dBmV but anything above 40 up to around 48 is good.
