Owen3
  • 13
Message 1 of 21
Slow Connection since Upgrading to Hub 4
Since Upgrading to Hub 4 last month, my connection speed is frequently much slower than it was before the "upgrade". If I try to run a test, I get the message "Unfortunately we can't run a diagnostic test on your Hub 4 yet. But, we're working on it so you'll be able run one soon."
Any suggestions on what can be done? The hub is in the same location as the previous one was. This is not good news for home working and any advice on how to improve the speed would be much appreciated. Thanks!
Kind Regards,
Owen
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 2 of 21
Re: Slow Connection since Upgrading to Hub 4
What speed do you get at >> Sam Knows Real Speed << using a direct connection using a Cat 5E/6 cable between the Hub in Router Mode and a 1Gbs capable Pc/Mac/Chromebook and no other devices connected ?
Owen3
  • 13
Message 3 of 21
Hi Mike,
Thanks for your quick reply. I probably have a Cat 5E/6 cable somewhere - but I don't have a port for one on my MacBook Air. Is there anything else I can try? When I go to the website, I get the following reading - for my iPad.
Owen
  • 25.17K
  • 2.61K
  • 4.59K
Message 4 of 21
FYI - I have a MBAir too and I connect it to the netwwork fine with a USB3-RJ45 ethernet adapter and Cat 6 cable. Worth having one in your tech drawer.
Owen3
  • 13
Message 5 of 21
Hi John,
Thanks for your reply. Would that adapter you mentioned work with a USB C port? I really want to get my broadband speed issued resolved but want to make sure I order the right adapter for my MacBook Air, as it doesn't have any normal USB ports.
BTW, is buying the cable the only way to troubleshoot the issue? I did upload a screen shot from Sam Knows Real Speed, as Mike had previously suggested – it was a reading for my iPad though and was obviously obtained wirelessly, as I don’t have an adapter for my iPad either (the port on the iPad, although very similar in size to the USB C on the MBAir, is different again – not sure what it is called.... It’s a shame the Apple products are not a bit more homogenous, it would be good to have one adapter that would work with both devices).
Alternatively, might it be a good idea to see if I can return the Hub 4 and get the Hub 3 back? The Hub 3 worked much better.
Thanks for your advice.
 Regards,
Owen
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 6 of 21
Plenty >> HERE <<.
Just make sure that it is Gigabit capable and as you probably know stick to the well known manufacturers.
Owen3
  • 13
Message 7 of 21
Hi Mike,
The adapter and cable I ordered just arrived today so I was able to follow your instructions. I'm not sure what the reading from the RealSpeed - SamKnows website means though - can you please advise? I'll past a screenshot below. Thanks!
Kind Regards, Owe
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 8 of 21
Can you just type the speed results please.
We might be waiting quite a while for a mod to get to the image then possibly reject it for content.
Owen3
  • 13
Message 9 of 21
Hi Mike,
It looks like the image has uploaded now - it says that the speed to the hub is 97.8. But, I only just noticed that is says the speed to the iPad is 93.0 - even though I've got it plugged into my MacBook Air... Even when I try to run the test again, with the iPad turned off, the website still only gives a result for the iPad. Can you advise how I can get it to take a reading for my MBAir?
Thanks, Owen
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 10 of 21
We have a problem because we are having to learn about the Hub 4 by reading problems and working out the ins and outs of the Hub.
What is your contracted speed ?
If nothing is showing try phoning 0800 561 0061, this will tell you of more local issues that may be affecting the area. Be aware that it isn't a manned line.
Go round all the accessible internal and external co-ax connections and ensure that they are finger tight.
If everything above is OK we need do some more troubleshooting; to start with …
Then
Can you please
