PaulChill
  • 8
Message 1 of 14
Slow Broadband
Broadband speed only around 50MPS - normally at least 250MPS.
WIFI mysteriously dropped on Wednesday in main home network but still worked in sub-network area (room upstairs).
Cannot access router as I get message stating someone else is already logged on (I suspect this is because I installed the VirginMediaConnect app on my ipad a while ago).
Tags (3)
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.93K
Message 2 of 14
Re: Slow Broadband
Lets sort out the Hub access problem to start with.
My advice ...
Uninstall the Connect App, it has more bugs then a tramps vest.
Reboot your phone.
Forget about the app.
Factory reset the Hub using this exact method ...
DO NOT DO THIS if the password on the base of the Hub is not legible or missing.
Instructions for Hub 3
Disconnect all unneeded ethernet cables from the rear of the Hub.
With the Hub Powered on use a paperclip or similar (I use a mobile phone SIM Slot tool) and do a pinhole reset.
DO NOT reboot the hub but allow it 5 to 10 minutes for it to boot itself up.
Once a steady white and no other lights are illuminated check your system again.
Save your sanity and health still forget about the Connect App.
Use the Hub GUI at 192.168.0.1 in your browser to make Hub Settings changes.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.93K
Message 3 of 14
Re: Slow Broadband
Once you have sorted the Hub access issue .
Please do this before posting the Hub Data
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.93K
Message 4 of 14
Re: Slow Broadband
Can you please
Hub 4 When the page appears LOG IN then Advanced Settings > Tools > Network Status.
Copy and paste the contents of the Downstream, Upstream, Configuration and Network Log tabs onto here, if you get a yellow / straw box warning click the Post button again.
Use one post for each tab if you wish.
Please do not use screen shots.
PaulChill
  • 8
Message 5 of 14
Re: Slow Broadband
PaulChill
  • 8
Message 6 of 14
Re: Slow Broadband
13310000001.238256 qam25
22030000002.938256 qam9
32110000002.938256 qam10
42190000002.740256 qam11
52270000002.538256 qam12
62350000002.238256 qam13
72430000001.738256 qam14
82510000001.238256 qam15
92590000000.738256 qam16
102670000000.438256 qam17
112750000000.738256 qam18
122830000001.440256 qam19
132910000001.438256 qam20
142990000001.538256 qam21
153070000001.538256 qam22
163150000001.538256 qam23
173230000001.438256 qam24
183710000000.238256 qam26
19379000000038256 qam27
20387000000-0.738256 qam28
21395000000-0.938256 qam29
22403000000-138256 qam30
23411000000-0.938256 qam31
24419000000-138256 qam32
1Locked38.960
2Locked38.940
3Locked38.950
4Locked40.930
5Locked38.950
6Locked38.960
7Locked38.940
8Locked38.940
9Locked38.950
10Locked38.910
11Locked38.650
12Locked40.3120
13Locked38.9100
14Locked38.950
15Locked38.950
16Locked38.950
17Locked38.9160
18Locked38.900
19Locked38.910
20Locked38.640
21Locked38.670
22Locked38.920
23Locked38.940
24Locked38.650
PaulChill
  • 8
Message 7 of 14
Re: Slow Broadband
Upstream bonded channelsChannel Frequency (Hz) Power (dBmV) Symbol Rate (ksps) Modulation Channel ID
13940000043512064 qam4
24620000043.3512064 qam3
35370000043.8512064 qam2
43260000042.5512064 qam5
Upstream bonded channelsChannel Channel Type T1 Timeouts T2 Timeouts T3 Timeouts T4 Timeouts
3ATDMA0000
4ATDMA0000
PaulChill
  • 8
Message 8 of 14
Re: Slow Broadband
General Configuration
Network access
Allowed
Maximum Number of CPEs
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
cmreg-vmdg505-bbt062-b.cm
SFID881880
Max Traffic Rate402500089
Max Traffic Burst42600
Min Traffic Rate0
Primary Upstream Service Flow
SFID881879
Max Traffic Rate38500089
Min Traffic Rate0
Max Concatenated Burst42600
Scheduling TypeBestEffort
PaulChill
  • 8
Message 9 of 14
Re: Slow Broadband
5/01/2021 13:06:43noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/01/2021 13:01:24noticeSW download Successful - Via Config file
15/01/2021 12:59:16noticeSW Download INIT - Via Config file
01/01/1970 00:01:40criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/01/2021 12:46:44noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/01/2021 12:46:41Warning!LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/01/2021 10:53:30noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:01:39criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/01/2021 14:24:47Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/01/2021 14:24:43Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/01/2021 14:24:43criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/01/2021 14:24:42Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/01/2021 14:24:42criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/01/2021 14:17:1Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/01/2021 14:16:7Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/01/2021 14:16:2criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/01/2021 14:16:2Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/01/2021 14:15:57Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/01/2021 13:36:37criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.93K
Message 10 of 14
Re: Slow Broadband
Your >> BQM << will need to run until about 14:00 on 16/1/21 to get a proper picture.
