RodgerB
Message 1 of 5
Slow Broadband
I’ve been suffering slow broadband in the Stevenage area for over a month ! Speed tested daily and no more than 107Mbps on a Virgin M350 package . Virgin Status states no area issues or equipment issues yet poor speed . Daily hard reset via pin hole and still no improvement .
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 2 of 5
Re: Slow Broadband
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 3 of 5
Re: Slow Broadband
Can you please
RodgerB
Message 4 of 5
Re: Slow Broadband
12590000005.937256 qam16
21390000007.838256 qam1
31470000007.937256 qam2
41550000007.837256 qam3
51630000006.837256 qam4
6171000000737256 qam5
71790000007.337256 qam6
81870000007.138256 qam7
91950000007.138256 qam8
102030000007.538256 qam9
112110000007.138256 qam10
122190000006.638256 qam11
132270000006.437256 qam12
142350000005.437256 qam13
152430000004.838256 qam14
162510000005.838256 qam15
172670000005.538256 qam17
182750000006.537256 qam18
192830000007.138256 qam19
202910000006.538256 qam20
212990000007.138256 qam21
223070000007.338256 qam22
233150000006.538256 qam23
243230000006.538256 qam24
Natalie_L
  • 2.65K
  • 120
  • 231
Message 5 of 5
Re: Slow Broadband
Hi RodgerB
Welcome to the Community and thank you for getting in touch.
I am very sorry to hear you have been experiencing issues with your broadband service.
i have gone ahead and taken a look from our side and all of your levels appear to be where we would expect.
Can you please confirm what speeds you are achieving on both wired and wireless connections?
Nat
