oliverb
  • 37
Message 1 of 26
Slow Broadband speed
(I have tried to resolve this issue via the Virgin Media Chat but at present after several attempts no response ... and life is much too short to get put on hold if I ring up)
Over the last week my Broadband speed has dipped to 80m and I'm paying for 200m ... this is via a hard wire connection and not via wifi ... plus I don't use the HUB3 for wifi it's set to modem only and has been for years.  My router is a Unifi USG which has never been an issue and I normally get speeds of 180m over ethernet.
Can someone from Virgin assist?
Cheers.
My Broadband Ping - Home
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 2 of 26
Re: Slow Broadband speed
Try another speed test with ethernet cable device without the Unifi USG in the network.
oliverb
  • 37
Message 3 of 26
I could do but then I think would need to switch my HUB3 back into Router mode ... and from what I remember switching it into Modem mode was a nightmare last time.
Plus can't say much has changed my end so would be good for the Big company to check there end before the Small consumer has to jump thru hoops 🙂
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 4 of 26
You don't need to put the Hub into Router Mode.
Your choice whether to test or not.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 5 of 26
Can you please
oliverb
  • 37
Message 6 of 26
Downstream:
Channel	Frequency (Hz)	Power (dBmV)	SNR (dB)	Modulation	Channel ID
1	323000000	-0.2	38	256 qam	24
2	203000000	-0.5	36	256 qam	9
3	211000000	-0.9	36	256 qam	10
4	219000000	-1	36	256 qam	11
5	227000000	-1.2	36	256 qam	12
6	235000000	-1.4	37	256 qam	13
7	243000000	-2.4	37	256 qam	14
8	251000000	-3.5	37	256 qam	15
9	259000000	-2.5	37	256 qam	16
10	267000000	-1.5	37	256 qam	17
11	275000000	-1.4	38	256 qam	18
12	283000000	-1	38	256 qam	19
13	291000000	-0.7	38	256 qam	20
14	299000000	-0.2	38	256 qam	21
15	307000000	-0.2	38	256 qam	22
16	315000000	-0.2	38	256 qam	23
17	331000000	-0.2	38	256 qam	25
18	371000000	-1	38	256 qam	26
19	379000000	-1.7	38	256 qam	27
20	387000000	-2	38	256 qam	28
21	395000000	-1.9	38	256 qam	29
22	403000000	-2	38	256 qam	30
23	411000000	-1.7	38	256 qam	31
24	419000000	-1.5	38	256 qam	32
Channel	Locked Status	RxMER (dB)	Pre RS Errors	Post RS Errors
1	Locked	38.6	61634	5158
2	Locked	36.3	339706	13193
3	Locked	36.3	473229	13077
4	Locked	36.6	331012	11506
5	Locked	36.6	296579	13349
6	Locked	37.6	266370	13079
7	Locked	37.3	324891	25529
8	Locked	37.6	396467	40747
9	Locked	37.6	310199	20595
10	Locked	37.6	268419	10020
11	Locked	38.6	198113	8689
12	Locked	38.6	167744	9126
13	Locked	38.9	140428	7939
14	Locked	38.6	78887	6333
15	Locked	38.9	84087	6118
16	Locked	38.9	79889	5682
17	Locked	38.6	90854	5322
18	Locked	38.9	75426	4648
19	Locked	38.9	92240	5126
20	Locked	38.6	101045	21049
21	Locked	38.6	110302	21400
22	Locked	38.6	113007	24016
23	Locked	38.6	129493	21465
24	Locked	38.6	102187	9828
Upstream
Channel	Frequency (Hz)	Power (dBmV)	Symbol Rate (ksps)	Modulation	Channel ID
1	53700038	47.8	5120	64 qam	5
2	25800000	47.8	5120	64 qam	4
3	39400135	47.8	5120	64 qam	2
4	46200000	47.5	5120	64 qam	3
Channel	Channel Type	T1 Timeouts	T2 Timeouts	T3 Timeouts	T4 Timeouts
1	ATDMA	0	0	12	0
2	ATDMA	0	0	6	0
3	ATDMA	0	0	4	0
4	ATDMA	0	0	5	0
Configuration
General Configuration
Network access
Allowed
Maximum Number of CPEs
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
cmreg-vmdg505-bbt060-b.cm
SFID	1214672
Max Traffic Rate	230000061
Max Traffic Burst	42600
Min Traffic Rate	0
Primary Upstream Service Flow
SFID	1214671
Max Traffic Rate	22000061
Min Traffic Rate	0
Max Concatenated Burst	42600
Scheduling Type	BestEffort
oliverb
  • 37
Message 7 of 26
My BQM
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 8 of 26
Your Pre & Post RS Error counts are very high.
In an ideal world they would be at zero and stay there. To zero them can you reboot the Hub using this method and then keep an eye on the counts.
Switch the Hub off using the small switch on the rear of the Hub next to the power cord and pull the PSU plug from the wall socket.
Give it a good 5 minutes put the plug back in and switch the Hub back on.
Allow the Hub a few minutes to fully restart then check the counts again in an hour or so.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 9 of 26
Apart from the RS Levels addressed above, your Hub data looks OK to me.
Can you Login to the Unifi USG Settings and navigate to the Connected Devices page - what is the reported 'connection speed’ for the ethernet cable connected device you used for the speed test ?
oliverb
  • 37
Message 10 of 26
I thought you had found the issue :), well you did in part ... the ethernet between my Unifi Switch and my USG was running at 100 rather than 1gb and so went and took at look and the uplink ethernet cable must have been damaged, so replace and now at 1gb ... and my speed has increased now but only to 106 (max after x3 attempts).
I will try again and directly connect my laptop to the modem (unsure if i'm doing it right, I swapped over my lead to my USG to my Laptop, set my Ip to 192.168.100.2, 255.255.255.0, gw 192.168.100.1, dns blank (presuming no dhcp so had to set myself), also I will try and work my way back up the chain, to see if the connection gets worse.
