BMWCHUBB
  • 133
  • 36
Up to speed
Slow Broadband - Wired and WiFi
My wired and wifi is like dialup...Whats going on vm?
  • 35.07K
  • 3.41K
  • 6.67K
Re: Slow Broadband - Wired and WiFi
See these...
__________
Have you checked for any “known network faults”
As well as trying the “check service,”Area status webpage" (link at top right of this forum), also try the “free & automated” Service Status number - 0800 561 0061 - which usually gives the most up to date info. and tells you of more local issues down to postcode level. These may not be listed on the Area Status web page (Areas are not “Geographic” they are billing areas) as that usually only covers faults affecting 1000’s of customers) so phone may give you more info, but even that wont cover problems affecting just a few customers - or just you.
______________________________________________________________
Do a Hub “pinhole reset” - first make sure the 2 passwords on the Hub sticker are still there and legible first ! Disconnect any ethernet cables from the Hub (leave the coax connected), and then with the Hub still "switched on" throughout, press pin in firmly with paper clip/SIM tray tool or similar "thin thing" and hold it firmly for at least 60 (a timed sixty) seconds, release the pin, leave for 5’ to stabilise - dont manually switch it off at any time. Passwords will reset to those on the sticker. See if that sorts it.
