Message 1 of 5
Slow Broadband Speed
Hi, I'm on M200, but just upgraded to M350 last week (apparently this will change from 3rd July), however, since the upgrade, I haven't achieved above 45mb download. Upload speeds hover around the 20mb mark. Any ideas?
1234750000-4.736256 qam13
2242750000-5.236256 qam14
3250750000-4.936256 qam15
4258750000-5.536256 qam16
5266750000-5.436256 qam17
6274750000-536256 qam18
7282750000-4.736256 qam19
8290750000-4.736256 qam20
9298750000-4.436256 qam21
10306750000-4.736256 qam22
11314750000-5.436256 qam23
12322750000-5.236256 qam24
13330750000-536256 qam25
14394750000-735256 qam26
15402750000-6.936256 qam27
16410750000-6.735256 qam28
17418750000-7.236256 qam29
18426750000-736256 qam30
19434750000-7.236256 qam31
20442750000-7.735256 qam32
21450750000-836256 qam33
22458750000-7.236256 qam34
23466750000-7.236256 qam35
24474750000-736256 qam36
1Locked36.6154277561996
2Locked36.6871401685
3Locked36.680962886
4Locked36.31021561209
5Locked36.31087961460
6Locked36.61267261287
7Locked36.6613151093
8Locked36.679933936
9Locked36.383355838
10Locked36.387255673
11Locked36.1115680612
12Locked36.1143021485
13Locked36.351276711
14Locked35.954089776
15Locked36.133725634
16Locked35.955089578
17Locked36.134440442
18Locked36.143187607
19Locked36.143881408
20Locked35.7105791378
21Locked36.320602409
22Locked36.129600505
23Locked36.332091522
24Locked36.614903340
Message 2 of 5
Re: Slow Broadband Speed
1394000695.1512064 qam4
2537001815.1512064 qam2
3462001185.1512064 qam3
4603000085.1512064 qam1
3ATDMA0000
4ATDMA0000
Message 3 of 5
09/06/2020 14:19:41Warning!LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
09/06/2020 02:09:59ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
06/06/2020 09:39:34criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
05/06/2020 17:36:54ErrorDHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
05/06/2020 03:10:2ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
04/06/2020 13:30:56criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
04/06/2020 12:43:15ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/06/2020 08:05:27criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
31/05/2020 02:46:50ErrorDHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
31/05/2020 00:09:26ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/05/2020 22:00:40criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/05/2020 05:48:0ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
29/05/2020 07:00:7Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
29/05/2020 07:00:7criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
29/05/2020 07:00:6Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
27/05/2020 13:46:46criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
27/05/2020 00:52:32ErrorDHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
26/05/2020 17:22:7ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
26/05/2020 16:08:28criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
25/05/2020 18:51:4ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
  • 15.71K
  • 1.64K
  • 2.68K
Message 4 of 5
You have connection issues - so can you reset the Hub as below - then leave it an hour or so and post up the new data as per you just did.
Note that a pinhole reset on a Hub3 can be a bit problematic - so do it EXACTLY this way (not as the VM website says!).
Firstly, make sure the Hub's sticker/card with the two passwords on it is still there and legible or you will be stuffed ! If its not – DON’T DO IT !
With the Hub switched "on", disconnect any ethernet connections and then push in the “reset pin” with the end of a paperclip/thin nail or similar (bigger items like ball point pen ends may not press it in far enough) until you feel it at the “stop point” and hold it there firmly for a "timed" minimum of 60 seconds do NOT restart the Hub after that. Leave it 10' or so to stabilise and then your passwords/passphrase for both the Hub settings and the Wifi networks will revert to the two printed on the Hub sticker on its base/side/card. Make sure you use the wifi one for devices connecting to the wifi and the settings/admin one to access the Hub (it is a six digit numeric one).
  • 4.49K
  • 263
  • 523
Message 5 of 5
Hello neilprior124
How are things looking now with the service,
I can see that you have inquired about a speed upgrade
Has this improved the service at all?
Gareth_L
