Message 1 of 5
Slow Broadband 350mb
I've recently joined Virgin broadband from Sky, the download speeds I'm getting are usually 50mb.
Since joining 2 weeks ago we have not had received anywhere near 350mb at anytime of the day.
Please would you advise if this is normal?
Thanks - Chris
Router status:-
Channel
Locked Status
RxMER (dB)
Pre RS Errors
Post RS Errors
1
Locked
40.3
30
523
2
Locked
40.3
4475
2094
3
Locked
40.3
2067
3393
4
Locked
40.3
1061
2251
5
Locked
40.3
1489
2850
6
Locked
40.9
3283
5001
7
Locked
40.3
1810
3241
8
Locked
40.3
1504
3418
9
Locked
40.3
59
8785
10
Locked
40.9
50
8841
11
Locked
40.9
57
8942
12
Locked
40.3
77
8947
13
Locked
40.9
54
8996
14
Locked
40.9
161
8941
15
Locked
40.9
52
8997
16
Locked
40.3
52
9364
17
Locked
40.9
134
724
18
Locked
40.3
50
794
19
Locked
40.3
191
9050
20
Locked
40.3
51
1013
21
Locked
40.3
41
1155
22
Locked
40.9
50
9417
23
Locked
40.3
69
9374
24
Locked
40.9
1333
8036
Channel
Frequency (Hz)
Power (dBmV)
Symbol Rate (ksps)
Modulation
Channel ID
1
39400000
4.25
5120
64 qam
62
2
25799986
4.175
5120
64 qam
64
3
32600161
4.225
5120
64 qam
63
4
46200000
4.25
5120
64 qam
61
Channel
Channel Type
T1 Timeouts
T2 Timeouts
T3 Timeouts
T4 Timeouts
1
ATDMA
0
0
0
0
2
ATDMA
0
0
0
0
3
ATDMA
0
0
0
0
4
ATDMA
0
0
0
0
General Configuration
Network access
Allowed
Maximum Number of CPEs
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
cmreg-vmdg505-rtsxxl35016u+voc-b.cm
SFID
34690
Max Traffic Rate
402500089
Max Traffic Burst
42600
Min Traffic Rate
0
Primary Upstream Service Flow
SFID
34689
Max Traffic Rate
38500089
Max Traffic Burst
42600
Min Traffic Rate
0
Max Concatenated Burst
42600
Scheduling Type
BestEffort
Time
Priority
Description
21/11/2019 09:37:35
critical
SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/11/2019 09:37:39
Warning!
Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/11/2019 09:40:11
critical
Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/11/2019 10:18:25
Warning!
RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/11/2019 10:18:27
critical
21/11/2019 10:18:27
Warning!
21/11/2019 10:18:27
critical
21/11/2019 10:18:32
Warning!
21/11/2019 10:19:4
Warning!
21/11/2019 10:28:45
critical
21/11/2019 10:28:45
Warning!
21/11/2019 10:28:45
critical
21/11/2019 10:28:50
Warning!
22/11/2019 12:32:5
critical
26/11/2019 05:21:36
Error
DHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
27/11/2019 12:51:39
Error
DHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
29/11/2019 23:30:44
critical
30/11/2019 13:02:54
Error
01/12/2019 08:44:12
Error
03/12/2019 21:56:43
critical
  • 3.54K
  • 569
  • 1.39K
Message 2 of 5
Re: Slow Broadband 350mb
SNR is OK, power levels for upstream are OK, but not shown for downstream, but the post-RS error levels are too high.  Unless there's an area fault already being worked on you'll need a technician to visit, so hold on for the VM forum staff to advise you - sometimes take a day or two, sometimes they get back to you very quickly..
Message 3 of 5
Great Thanks for your quick response Andruser!
Message 4 of 5
Hi VM
Please would you arrange for a technician to visit?
Thanks - Chris
  • 2.73K
  • 205
  • 272
Message 5 of 5
Sorry to heat that you're having issues with your services and that you need a technician visit to fix this.
I will send over a private message in a few moments with a request for some account details so that we can pass account security and look into your issue.
Steven_L
