on 01-09-2021 17:22
Slow single thread speed (25Mbps), when carrying tasks out such as downloading.
all tests carried out over ethernet
Answered! Go to Answer
on 01-09-2021 20:42
on 01-09-2021 17:22
Post up your Connection details and someone will check to see if there is a problem.
In your browser’s URL box type in http://192.168.0.1 (or http://192.168.100.1 - if in modem mode) hit return.
On the first page click on the “router status” icon/text at bottom-middle of first page up and then copy/paste as “Formatted Text” (not images)
FULL sets of data onto here
pages from the Downstream
from the Upstream & the Network Logs page.
Mac, IP addresses will be blanked out when you submit and have to do this twice
Please also set up a “Broadband Quality Monitor” to monitor the state of your connection and record any true network dropouts, latency issues, packet loss.
It will allow you to identify issues It does it 24/7/365 and it keeps a visual record of any/all of your network disconnections, useful data to have to match to the Network logs (in your Hub settings) post the “link” to the “share live graph” (as per instructions on the TB website) when it starts to develop.
RR The IT GUY
on 01-09-2021 17:31
Acquired Downstream Channel (Hz) | 203000000 | Locked |
Ranged Upstream Channel (Hz) | 53700000 | Locked |
Provisioning State | Online |
1 | 203000000 | 0 | 37 | 256 qam | 9 |
2 | 139000000 | 2 | 37 | 256 qam | 1 |
3 | 147000000 | 1.7 | 37 | 256 qam | 2 |
4 | 155000000 | 1.4 | 37 | 256 qam | 3 |
5 | 163000000 | 1.4 | 37 | 256 qam | 4 |
6 | 171000000 | 1.2 | 37 | 256 qam | 5 |
7 | 179000000 | 1 | 37 | 256 qam | 6 |
8 | 187000000 | 0.7 | 37 | 256 qam | 7 |
9 | 195000000 | 0.2 | 37 | 256 qam | 8 |
10 | 211000000 | -0.2 | 37 | 256 qam | 10 |
11 | 219000000 | -0.4 | 37 | 256 qam | 11 |
12 | 227000000 | -0.7 | 37 | 256 qam | 12 |
13 | 235000000 | -0.9 | 37 | 256 qam | 13 |
14 | 243000000 | -2 | 37 | 256 qam | 14 |
15 | 251000000 | -3.5 | 37 | 256 qam | 15 |
16 | 259000000 | -2.4 | 37 | 256 qam | 16 |
17 | 267000000 | -1.5 | 37 | 256 qam | 17 |
18 | 275000000 | -1.2 | 37 | 256 qam | 18 |
19 | 283000000 | -0.9 | 37 | 256 qam | 19 |
20 | 291000000 | -0.7 | 37 | 256 qam | 20 |
21 | 299000000 | -0.2 | 37 | 256 qam | 21 |
22 | 307000000 | 0 | 37 | 256 qam | 22 |
23 | 315000000 | 1.2 | 37 | 256 qam | 23 |
24 | 323000000 | 2.2 | 37 | 256 qam | 24 |
1 | Locked | 37.3 | 2160 | 9093 |
2 | Locked | 37.6 | 3126 | 14715 |
3 | Locked | 37.3 | 2910 | 12657 |
4 | Locked | 37.3 | 3177 | 11141 |
5 | Locked | 37.6 | 2666 | 11064 |
6 | Locked | 37.3 | 2509 | 15569 |
7 | Locked | 37.6 | 1917 | 11362 |
8 | Locked | 37.3 | 2094 | 10835 |
9 | Locked | 37.6 | 1999 | 9716 |
10 | Locked | 37.3 | 2171 | 8482 |
11 | Locked | 37.6 | 2035 | 8910 |
12 | Locked | 37.3 | 1865 | 9143 |
13 | Locked | 37.3 | 1842 | 9759 |
14 | Locked | 37.3 | 2660 | 9869 |
15 | Locked | 37.6 | 5652 | 9923 |
16 | Locked | 37.3 | 3772 | 9198 |
17 | Locked | 37.3 | 1973 | 8541 |
18 | Locked | 37.6 | 2064 | 8738 |
19 | Locked | 37.3 | 1866 | 7575 |
20 | Locked | 37.6 | 1856 | 6644 |
21 | Locked | 37.3 | 1891 | 5216 |
22 | Locked | 37.6 | 1792 | 3957 |
23 | Locked | 37.6 | 1702 | 3514 |
24 | Locked | 37.6 | 1620 | 4102 |
on 01-09-2021 17:32
1 | 53700000 | 51 | 5120 | 64 qam | 2 |
2 | 39400131 | 51 | 5120 | 64 qam | 4 |
3 | 46200206 | 51 | 5120 | 64 qam | 3 |
4 | 60299819 | 51 | 5120 | 64 qam | 1 |
1 | ATDMA | 0 | 0 | 1 | 0 |
2 | ATDMA | 0 | 0 | 0 | 0 |
3 | ATDMA | 0 | 0 | 1 | 0 |
4 | ATDMA | 0 | 0 | 3 | 0 |
General Configuration
Network access | Allowed |
Maximum Number of CPEs | 1 |
Baseline Privacy | Enabled |
DOCSIS Mode | Docsis30 |
Config file | cmreg-vmdg505-bbt062-b.cm |
SFID | 311766 |
Max Traffic Rate | 402500089 |
Max Traffic Burst | 42600 |
Min Traffic Rate | 0 |
SFID | 311765 |
Max Traffic Rate | 38500089 |
Max Concatenated Burst | 42600 |
Scheduling Type | BestEffort |
Network LogTime Priority Description
01/09/2021 12:04:53 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
31/08/2021 08:44:28 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
31/08/2021 02:51:46 | Error | DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
28/08/2021 02:39:43 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
28/08/2021 00:44:22 | Error | DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
27/08/2021 13:19:51 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
26/08/2021 12:45:34 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
26/08/2021 12:45:34 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
26/08/2021 12:45:32 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
26/08/2021 12:45:32 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
25/08/2021 10:53:45 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
25/08/2021 10:53:45 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
25/08/2021 10:53:34 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
24/08/2021 04:37:58 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
23/08/2021 15:59:14 | Error | DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
20/08/2021 10:57:34 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
20/08/2021 03:59:14 | Error | DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
19/08/2021 07:08:48 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
16/08/2021 19:20:16 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
16/08/2021 15:59:14 | Error | DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
01-09-2021 17:35 - edited 01-09-2021 17:42
Power levels look good however same can't be said for the Pre RS Errors Post RS Errors, would you mind giving us a hub reboot then submitting more stats later on?
Also meant to ask what your broadband speed is as from what i can see it looks like M350?
01-09-2021 17:54 - edited 01-09-2021 17:58
To confirm it is a M350
and have rebooted now
I am getting slow speeds still Single thread 17:57
on 01-09-2021 18:17
above is a thinkbroadband test file as you can see the speed is very slow
Nvedea driver downloads
OVH data centres download speed
on 01-09-2021 18:38
01-09-2021 18:46 - edited 01-09-2021 19:00
thanks for spotting that, I had not.
You will need an engineer to check your tap to check if its good and you will also need to check how many splitters you have for TV services and make sure there are less. The cables should really be replaced and ideally the splitter should be replaced for a powered splitter if there are a few cable devices such as TV's however the downstream looks good so that might cause another issue? I'll let someone here see what they think.
Would someone mind flagging this up for the forum team to get an engineer booked.
on 01-09-2021 20:42
