Show0ff
  • 6
Message 1 of 10
Signed up for M500 only getting about 260 wired and less wireless
Hi All.
I recently upgraded to M500 from M200 and not getting anything like the speed I'm now paying for.
Can someone please help or point me to someone who can?
Hub 3.0, Netgear R8000 Nighthawk AC3200
My BQM
14190000004.538256 qam32
22030000004.338256 qam9
32110000004.438256 qam10
42190000004.538256 qam11
52270000004.338256 qam12
6235000000438256 qam13
72430000003.938256 qam14
82510000003.738256 qam15
92590000003.738256 qam16
10267000000438256 qam17
112750000004.138256 qam18
122830000004.438256 qam19
132910000004.538256 qam20
142990000004.938256 qam21
15307000000538256 qam22
163150000004.838256 qam23
173230000004.938256 qam24
183310000005.138256 qam25
19371000000538256 qam26
203790000004.538256 qam27
213870000004.138256 qam28
223950000004.438256 qam29
234030000004.538256 qam30
244110000004.538256 qam31
1Locked38.9100
2Locked38.624390
3Locked38.6369711
4Locked38.927843190
5Locked38.934404134
6Locked38.942723864
7Locked38.643094103
8Locked38.638451137
9Locked38.94611525
10Locked38.648541551
11Locked38.95018873
12Locked38.922821
13Locked38.923301
14Locked38.920274663
15Locked38.9440
16Locked38.91980
17Locked38.92900
18Locked38.91430
19Locked38.920
20Locked38.970
21Locked38.9220
22Locked38.970
23Locked38.9130
24Locked38.960
Show0ff
  • 6
Message 2 of 10
Re: Signed up for M500 only getting about 260 wired and less wireless
16030000041.8512064 qam1
23940000040.5512064 qam4
34620000041512064 qam3
45370000041.3512064 qam2
3ATDMA0000
4ATDMA0000
14/02/2021 14:31:56Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/02/2021 08:21:5ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/02/2021 22:49:58criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
29/01/2021 20:21:5ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
28/01/2021 01:24:28criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
26/01/2021 08:21:5ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/01/2021 07:37:37criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/01/2021 20:21:5ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/01/2021 00:45:50criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
19/01/2021 08:21:5ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
16/01/2021 21:38:27criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
16/01/2021 01:16:49ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
13/01/2021 22:24:52criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/01/2021 02:25:20ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
09/01/2021 11:07:9criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
09/01/2021 06:32:34ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:01:41criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
07/01/2021 03:44:23noticeSW download Successful - Via NMS
07/01/2021 03:41:26noticeSW Download INIT - Via NMS
04/01/2021 12:37:24criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
  • 20.51K
  • 2.18K
  • 3.62K
Message 3 of 10
Can you first test speeds directly like this. As you expect >100Mbps then connect a 1GB enabled computer/laptop, with up to date drivers, via a known good and working Cat5e (or better) ethernet cable, directly to the Hub which you have put into “modem mode” after unplugging your router and any other devices (see VM website for “How To”). Test at speedtest.net (not using their App!) to your nearest VM server - try on 2 different browsers.
If they are still low – boot the device into windows safe+networking mode and try again.
There are many posts on here where unknown/flaky software, old network card drivers, corrupted browsers, bad cables or other connected devices are limiting speeds on tests.
Report back what that gets.
Show0ff
  • 6
Message 4 of 10
Tried what you suggested, but when plugged directly into the Hub in either 1 or 4, there was no internet at all. What am I missing?
I tried to turn off and on the Hub and PC, nothing worked.
Thanks.
  • 20.51K
  • 2.18K
  • 3.62K
Message 5 of 10
What did you plug in and did you try several cables?
In modem mode only one port is active - did you pull out any other connections you have in the other ports? If not - one of them was probably the active one
  • 15.42K
  • 662
  • 1.51K
Message 6 of 10
With the hub in modem mode turn off for 2mins to allow a new device.
Show0ff
  • 6
Message 7 of 10
I plugged in the cable from the PC which I know works fine into all the ports in the hub. Nothing else was plugged in.
I’ll leave it off for two minutes and try again.
Wolfclaw
  • 145
  • 54
Superfast
Message 8 of 10
Join the club mate, VM network just cannot handle the requirements, plain and simple, and they just keep pushing for new customers or higher speed upgrades. As they say in the gaming industry, if the whales are prepared to pay, just keep milking them !
Show0ff
  • 6
Message 9 of 10
So connecting directly to the Hub3 (in modem) I do indeed get 516mb.
So I guess my Netgear R8000 Nighthawk is holding it back?
Need to upgrade my router if that’s the case, any suggestions?
Brava210
  • 255
  • 36
Fibre optic
Message 10 of 10
I had the same Netgear R Series Router, it was nothing but trouble.
Asus AX56 is a very good router
Virgin 350 Hub 3, 3 x V6, TP-Link Deco AX20 x1, M5 x2 - United Artists/Telewest/VM Since 1990
