Roseblade666
  • 13
Message 1 of 7
Shocking 1GB speed!
I'm on the 1 gig fibre package and ive never even seen about 550mb. My samknows speed is currently maxing out around 350-400mb, ive done hard resets, soft resets, repositioned the modem and still no improvement. Am i doing something wrong or have a got a genuinely bad connection?20200828_210419.jpg
Anonymous
Not applicable
Message 2 of 7
Re: Shocking 1GB speed!
Is this wired or wireless devices?
jhuk
  • 3K
  • 52
  • 286
Problem sorter
Message 3 of 7
Well that is the internal speed so it is from the VM Coax to the HUB4, nothing to do with his side be it Wired or WIFI, only thing he would need check is the tightness of F-Connector at HUB4 after he fitted it (as in my case nothing else was changed/touched).
I can beat that.
This morning at 1:16am
Ran this 10 seconds after the above.
Roseblade666
  • 13
Message 4 of 7
Both wired and wireless, the speed fluctuates massively and drops as low as 40mbs at the router most days, F connections are good and have tried 3 different virgin supplied coax cables.
Paul_DN
  • 5.88K
  • 348
  • 625
Message 5 of 7
Hi Roseblade666,
Thank you for reaching out to us in our community and welcome, I am sorry to hear you aren't happy with the speeds you are getting, with our gigabit speed and the new super hub 4.0 the speed test we use is Sam knows, to get a correct reading you would need to put the router in modem mode and test using a wired connection, the device should have a gigabit network card and using a cat 6 or above cable, please disconnect everything from the router other than the one wired device while testing.
Paul.
Anonymous
Not applicable
Message 6 of 7
@Paul_DN wrote:
Hi Roseblade666,
Paul.
Why does it have to be in modem mode?
You should get around 940Mbps on ethernet regardless of mode?
Paul_DN
  • 5.88K
  • 348
  • 625
Message 7 of 7
Hi Carl,
The reason we advise putting it in modem mode is to eliminate everything else and check what speed the router is getting.
Paul.
