Barnesc
  • 6
Severe lag spikes and packet loss.
I have been connected with Virgin at my current property for just under a year now, and the connection has been great! Recently I got upgraded from the Hub3 to the Hub4, and that also went smoothly. I have been on the Hub4 for a month or so now.
However within the past few days I have been having extreme lag spikes, and it makes playing any sort of games impossible. I usually hover around 40ms ping, and then have long periods of 200+ms.
I have looked around and seen similar posts before so I have gone ahead and already set up the BQM https://www.thinkbroadband.com/broadband/monitoring/quality/share/7e2c642842a74b0cfa26129d39032b1c2e....
I will post the Network Configuration settings from the router in subsequent comments to this post. Hopefully someone can take a look and identify what might be going on. I don't know if its related, but it does feel like this has started as the weather has recently taken a turn, but i wouldn't have thought this would be the cause?
Tags (2)
Barnesc
  • 6
Re: Severe lag spikes and packet loss.
Item Status CommentsChannel Overview Downstream Upstream
Cable Modem Status
Online
DOCSIS 3.1
Primary downstream channel
Locked
SC-QAM
DOCSIS 3.0 channels
31
4
DOCSIS 3.1 channels
1
0
Barnesc
  • 6
3.0 Downstream channels
293630000008.69999740.366287QAM25629
1021100000011.69999740.366287QAM25610
1121900000011.59999840.366287QAM25611
1222700000011.09999840.366287QAM25612
1323500000011.09999840.366287QAM25613
1424300000010.30000340.946209QAM25614
1525100000010.40000240.366287QAM25615
162590000009.40000240.946209QAM25616
172670000009.50000040.366287QAM25617
182750000008.90000240.366287QAM25618
192830000008.59999840.366287QAM25619
202910000008.40000240.366287QAM25620
212990000009.59999840.366287QAM25621
223070000009.40000240.366287QAM25622
233150000009.19999740.366287QAM25623
243230000007.90000240.366287QAM25624
253310000008.90000240.366287QAM25625
263390000008.90000240.366287QAM25626
273470000009.00000040.366287QAM25627
283550000008.19999740.366287QAM25628
303710000008.50000040.366287QAM25630
313790000009.00000040.946209QAM25631
113900000014.90000240.946209QAM2561
214700000014.00000040.946209QAM2562
315500000013.80000340.946209QAM2563
416300000013.30000340.366287QAM2564
517100000012.80000340.946209QAM2565
617900000012.19999740.366287QAM2566
718700000012.40000240.946209QAM2567
819500000012.09999840.366287QAM2568
920300000012.19999740.366287QAM2569
29Locked000
10Locked3741322100
11Locked6719989100
12Locked6643998600
13Locked3725102600
14Locked3703547200
15Locked3458853600
16Locked4367681600
17Locked1245148800
18Locked1231378300
19Locked1094499300
20Locked1048247600
21Locked1231099600
22Locked1229481800
23Locked1098780500
24Locked2918127000
25Locked3102432000
26Locked3097549300
27Locked17430001700
28Locked3001651700
30Locked3019419400
31Locked319532551600
1Locked3996901400
2Locked4003600200
3Locked3551262300
4Locked310367566100
5Locked4012715200
6Locked3956982100
7Locked189305415000
8Locked3485561500
9Locked6413045800
3.1 Downstream channelsChannel Channel Width (MHz) FFT Type Number of Active Subcarriers Modulation (Active Profile) First Active Subcarrier (Hz)
159964K1880QAM4096759
3.1 Downstream channelsChannel ID Lock Status RxMER Data (dB) PLC Power (dBmV) Correcteds (Active Profile) Uncorrectables (Active Profile)
159Locked 0.04378388140
Barnesc
  • 6
3.0 Upstream channels
14620000038.5205995120 KSym/sec64QAM3
23940000037.7705995120 KSym/sec32QAM4
35370000039.2705995120 KSym/sec64QAM2
46030000039.7705995120 KSym/sec64QAM1
1US_TYPE_STDMA0000
2US_TYPE_STDMA0000
3US_TYPE_STDMA0000
4US_TYPE_STDMA0000
Barnesc
  • 6
Sun 20/09/2020 20:36:323No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Mon 21/09/2020 11:51:445MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Mon 21/09/2020 12:04:015DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Mon 21/09/2020 12:32:364DHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Mon 21/09/2020 12:43:534DHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Mon 21/09/2020 12:43:536DHCP Renew - lease parameters tftp file-cmreg-vmdg640-bbt062+voc-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Mon 21/09/2020 13:50:514DHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Mon 21/09/2020 14:09:114DHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Mon 21/09/2020 14:09:116DHCP Renew - lease parameters tftp file-cmreg-vmdg640-bbt062+voc-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sat 26/09/2020 09:39:094DHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sun 27/09/2020 17:09:134DHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sun 27/09/2020 17:09:136DHCP Renew - lease parameters tftp file-cmreg-vmdg640-bbt062+voc-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Mon 28/09/2020 12:04:573No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Wed 30/09/2020 17:20:224DHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Thu 01/10/2020 13:01:404DHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Thu 01/10/2020 13:01:406DHCP Renew - lease parameters tftp file-cmreg-vmdg640-bbt062+voc-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Tue 06/10/2020 03:06:484DHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Wed 07/10/2020 09:08:144DHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Wed 07/10/2020 09:08:146DHCP Renew - lease parameters tftp file-cmreg-vmdg640-bbt062+voc-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sat 10/10/2020 14:03:384DHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sun 11/10/2020 11:02:274DHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sun 11/10/2020 11:02:276DHCP Renew - lease parameters tftp file-cmreg-vmdg640-bbt062+voc-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Tue 13/10/2020 21:46:456CM-STATUS message sent. Event Type Code: 24; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 2.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Thu 15/10/2020 20:58:524DHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sat 17/10/2020 01:52:304DHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sat 17/10/2020 01:52:306DHCP Renew - lease parameters tftp file-cmreg-vmdg640-bbt062+voc-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sat 17/10/2020 18:53:153No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Tue 20/10/2020 10:25:314DHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Wed 21/10/2020 08:23:424DHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Wed 21/10/2020 08:23:426DHCP Renew - lease parameters tftp file-cmreg-vmdg640-bbt062+voc-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sat 24/10/2020 15:51:463No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sun 25/10/2020 14:09:414DHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sun 25/10/2020 15:22:215MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sun 25/10/2020 15:34:405DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Tue 27/10/2020 02:33:183No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Wed 28/10/2020 01:59:065Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Wed 28/10/2020 02:00:233Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Wed 28/10/2020 02:04:073No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Wed 28/10/2020 02:05:115B-INIT-RNG Failure - Retries exceeded;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Wed 28/10/2020 02:05:363No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Wed 28/10/2020 02:07:525MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Wed 28/10/2020 02:07:553No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Wed 28/10/2020 02:20:235DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Wed 28/10/2020 02:37:304DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Wed 28/10/2020 02:37:306DHCP Renew - lease parameters tftp file-cmreg-vmdg640-bbt062+voc-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Wed 28/10/2020 07:13:573No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
At least half of your Downstream Power Levels are too hig...
At least half of your Downstream Power Levels are too high.
This will need an engineer to put right.
You can either phone in (08:00 is the best time) or wait on here for a few days (6 to 7 days average) until one of the VM Forum Staff comes along.
