Serious ping problems - erratic
Rogueywon
I've been having erratic issues with ping for a few weeks now. Thought it might be a recurrence of an earlier issue with my coax cable, but no longer sure this is the case. Router stats:
3.0 Downstream channels
263387500007.90000240.946209QAM25626
11387500007.59999838.983261QAM2561
21467500007.59999838.983261QAM2562
31547500007.19999738.983261QAM2563
41627500007.09999838.983261QAM2564
51707500007.19999738.983261QAM2565
61787500007.19999740.366287QAM2566
71867500007.19999738.983261QAM2567
81947500007.09999838.983261QAM2568
92027500007.09999838.983261QAM2569
102107500007.09999838.983261QAM25610
112187500007.00000038.983261QAM25611
122267500006.80000338.983261QAM25612
132347500006.59999838.605377QAM25613
142427500006.80000338.983261QAM25614
152507500006.80000338.983261QAM25615
162587500006.90000240.366287QAM25616
172667500006.90000240.366287QAM25617
182747500007.40000240.366287QAM25618
192827500007.59999838.983261QAM25619
202907500007.90000238.983261QAM25620
212987500007.40000240.366287QAM25621
223067500007.30000340.366287QAM25622
233147500007.50000040.366287QAM25623
243227500008.00000040.946209QAM25624
253307500008.30000340.366287QAM25625
273467500007.50000040.366287QAM25627
283547500007.19999738.983261QAM25628
293627500007.00000038.983261QAM25629
303707500006.80000338.983261QAM25630
313787500006.19999738.605377QAM25631
26Locked40.94620960
1Locked38.98326100
2Locked38.98326150
3Locked38.98326100
4Locked38.98326100
5Locked38.98326160
6Locked40.36628700
7Locked38.98326100
8Locked38.98326100
9Locked38.98326100
10Locked38.98326180
11Locked38.98326110
12Locked38.98326100
13Locked38.60537760
14Locked38.98326100
15Locked38.98326170
16Locked40.36628750
17Locked40.36628700
18Locked40.36628760
19Locked38.98326100
20Locked38.98326170
21Locked40.36628700
22Locked40.36628700
23Locked40.36628700
24Locked40.94620980
25Locked40.36628700
27Locked40.36628700
28Locked38.98326100
29Locked38.98326100
30Locked38.98326100
31Locked38.60537700
3.1 Downstream channels
159944K1840QAM1024424
159Locked437.3513956860
60 REPLIES 60
I've posted most of this on previous pages, but will do so again. Ping is terrible this evening - and I note my upstream speed is down from its usual level in speedtest. Implies there's an upstream congestion issue?
Cable Modem StatusItem Status CommentsChannel Overview Downstream Upstream
Cable Modem Status
Online
DOCSIS 3.1
Primary downstream channel
Locked
SC-QAM
DOCSIS 3.0 channels
31
4
DOCSIS 3.1 channels
1
0
11387500007.00000038.983261QAM2561
21467500006.80000338.605377QAM2562
31547500006.19999738.983261QAM2563
41627500006.09999838.983261QAM2564
51707500006.09999838.983261QAM2565
61787500006.19999740.366287QAM2566
71867500006.09999840.946209QAM2567
81947500005.90000238.605377QAM2568
92027500005.69999738.983261QAM2569
102107500005.50000038.983261QAM25610
112187500005.50000038.605377QAM25611
122267500005.30000338.983261QAM25612
132347500005.09999838.983261QAM25613
142427500005.00000038.983261QAM25614
152507500004.80000338.605377QAM25615
162587500004.69999738.983261QAM25616
172667500004.69999738.983261QAM25617
182747500005.19999738.983261QAM25618
192827500005.59999838.983261QAM25619
202907500006.40000238.983261QAM25620
212987500006.30000340.366287QAM25621
223067500005.90000240.366287QAM25622
233147500006.00000040.366287QAM25623
243227500006.30000340.366287QAM25624
253307500006.40000240.366287QAM25625
263387500005.80000338.983261QAM25626
273467500005.40000240.366287QAM25627
283547500005.19999738.983261QAM25628
293627500005.09999838.605377QAM25629
303707500005.00000038.605377QAM25630
313787500004.30000338.983261QAM25631
1Locked38.98326100
2Locked38.60537700
3Locked38.98326100
4Locked38.98326100
5Locked38.98326100
6Locked40.36628700
7Locked40.94620900
8Locked38.60537700
9Locked38.98326100
10Locked38.98326100
11Locked38.60537700
12Locked38.98326100
13Locked38.98326100
14Locked38.98326100
15Locked38.60537700
16Locked38.98326100
17Locked38.98326100
18Locked38.98326100
19Locked38.98326100
20Locked38.98326100
21Locked40.36628700
22Locked40.36628700
23Locked40.36628700
24Locked40.36628700
25Locked40.36628700
26Locked38.98326100
27Locked40.36628700
28Locked38.98326100
29Locked38.60537700
30Locked38.60537700
31Locked38.98326100
159944K1800QAM4096424
159Locked424.326234800
3.0 Upstream channels
13260000042.0205995120 KSym/sec64QAM4
22580000041.5205995120 KSym/sec64QAM5
33940000042.5205995120 KSym/sec64QAM3
44620000042.0205995120 KSym/sec64QAM2
1US_TYPE_ATDMA0000
2US_TYPE_ATDMA0000
3US_TYPE_ATDMA0000
4US_TYPE_ATDMA0000
General Configuration
Network access
true
Maximum Number of CPEs
1
Baseline Privacy
true
DOCSIS Mode
3.1
Config file
kfoA,.iyewrkldJKDHSUBsgvc
SFID
21554
Max Traffic Rate
1200000450
Max Traffic Burst
42600
Min Traffic Rate
0
Primary Upstream Service Flow
SFID
21557
Max Traffic Rate
55000270
Max Traffic Burst
42600
Min Traffic Rate
0
Max Concatenated Burst
16320
Scheduling Type
bestEffort
Sun Mar
26
5MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sun Mar
26
6CM-STATUS message sent. Event Type Code: 24; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 1.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sun Mar
26
3No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sun Mar
26
Sun Mar
26
6DHCP Renew - lease parameters tftp file-cmreg-vmdg640-bbt076-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sun Mar
26
4DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sat Mar
25
Sat Mar
25
Fri Mar
24
Fri Mar
24
Fri Mar
24
Fri Mar
24
3SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Thu Mar
23
6CM-STATUS message sent. Event Type Code: 24; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 3.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Thu Mar
23
5DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
https://www.thinkbroadband.com/broadband/monitoring/quality/share/514d6fbb54a0b2e7ef89c203f4c80b8ad480bada
jpeg1
There's nothing wrong with your connection data. You have the common problem of sharing your local network with too many users that Virginmedia have signed up to use it.
You can complain of course, but...
- jpeg1
My name is NOT Alessandro. That's just a tag Virginmedia sticks on some contributors. Please ignore it.
Hi @Rogueywon thanks for getting back to us.
Sorry to hear of your ping issues and for any inconvenience this may be causing your household. I would like to have a look on your behalf. I am going to send you a private message. Please look out for the purple envelope in the top right of your screen.
Lee_R
After a week of being pretty much fine (other than the national outages on Tuesday, of course), the ping's gone to hell again this evening.
Adri_G
Hey Rogueywon, thanks for keeping the thread updated with this.
I am sorry to read the connection issue has re-occurred, I can see you've previously spoken to our forum team privately a couple of times and we've offered support with this.
Could you please confirm if this was a fix by tech visit we did last time and has your hub been replaced recently?
Upon our latest checks there are no known issues in your area network to explain this issue at this time.
Please, can you confirm whether you have any 3rd party equipment currently in use and if you have access to broadband and Wi Fi currently?
Let us know where you are with this and we're here to assist.
Adri
Your shared BQM is still showing over utilisation in peak hours, as pointed out by @jpeg1   last week.  The time scale for fixing such issues can be quite long.
jpeg1
But @Adri_G is following this, so hopefully they will be able to get something done to resolve it.
- jpeg1
