on 15-02-2023 22:01
I've been having erratic issues with ping for a few weeks now. Thought it might be a recurrence of an earlier issue with my coax cable, but no longer sure this is the case. Router stats:
26 | 338750000 | 7.900002 | 40.946209 | QAM256 | 26 |
1 | 138750000 | 7.599998 | 38.983261 | QAM256 | 1 |
2 | 146750000 | 7.599998 | 38.983261 | QAM256 | 2 |
3 | 154750000 | 7.199997 | 38.983261 | QAM256 | 3 |
4 | 162750000 | 7.099998 | 38.983261 | QAM256 | 4 |
5 | 170750000 | 7.199997 | 38.983261 | QAM256 | 5 |
6 | 178750000 | 7.199997 | 40.366287 | QAM256 | 6 |
7 | 186750000 | 7.199997 | 38.983261 | QAM256 | 7 |
8 | 194750000 | 7.099998 | 38.983261 | QAM256 | 8 |
9 | 202750000 | 7.099998 | 38.983261 | QAM256 | 9 |
10 | 210750000 | 7.099998 | 38.983261 | QAM256 | 10 |
11 | 218750000 | 7.000000 | 38.983261 | QAM256 | 11 |
12 | 226750000 | 6.800003 | 38.983261 | QAM256 | 12 |
13 | 234750000 | 6.599998 | 38.605377 | QAM256 | 13 |
14 | 242750000 | 6.800003 | 38.983261 | QAM256 | 14 |
15 | 250750000 | 6.800003 | 38.983261 | QAM256 | 15 |
16 | 258750000 | 6.900002 | 40.366287 | QAM256 | 16 |
17 | 266750000 | 6.900002 | 40.366287 | QAM256 | 17 |
18 | 274750000 | 7.400002 | 40.366287 | QAM256 | 18 |
19 | 282750000 | 7.599998 | 38.983261 | QAM256 | 19 |
20 | 290750000 | 7.900002 | 38.983261 | QAM256 | 20 |
21 | 298750000 | 7.400002 | 40.366287 | QAM256 | 21 |
22 | 306750000 | 7.300003 | 40.366287 | QAM256 | 22 |
23 | 314750000 | 7.500000 | 40.366287 | QAM256 | 23 |
24 | 322750000 | 8.000000 | 40.946209 | QAM256 | 24 |
25 | 330750000 | 8.300003 | 40.366287 | QAM256 | 25 |
27 | 346750000 | 7.500000 | 40.366287 | QAM256 | 27 |
28 | 354750000 | 7.199997 | 38.983261 | QAM256 | 28 |
29 | 362750000 | 7.000000 | 38.983261 | QAM256 | 29 |
30 | 370750000 | 6.800003 | 38.983261 | QAM256 | 30 |
31 | 378750000 | 6.199997 | 38.605377 | QAM256 | 31 |
26 | Locked | 40.946209 | 6 | 0 |
1 | Locked | 38.983261 | 0 | 0 |
2 | Locked | 38.983261 | 5 | 0 |
3 | Locked | 38.983261 | 0 | 0 |
4 | Locked | 38.983261 | 0 | 0 |
5 | Locked | 38.983261 | 6 | 0 |
6 | Locked | 40.366287 | 0 | 0 |
7 | Locked | 38.983261 | 0 | 0 |
8 | Locked | 38.983261 | 0 | 0 |
9 | Locked | 38.983261 | 0 | 0 |
10 | Locked | 38.983261 | 8 | 0 |
11 | Locked | 38.983261 | 1 | 0 |
12 | Locked | 38.983261 | 0 | 0 |
13 | Locked | 38.605377 | 6 | 0 |
14 | Locked | 38.983261 | 0 | 0 |
15 | Locked | 38.983261 | 7 | 0 |
16 | Locked | 40.366287 | 5 | 0 |
17 | Locked | 40.366287 | 0 | 0 |
18 | Locked | 40.366287 | 6 | 0 |
19 | Locked | 38.983261 | 0 | 0 |
20 | Locked | 38.983261 | 7 | 0 |
21 | Locked | 40.366287 | 0 | 0 |
22 | Locked | 40.366287 | 0 | 0 |
23 | Locked | 40.366287 | 0 | 0 |
24 | Locked | 40.946209 | 8 | 0 |
25 | Locked | 40.366287 | 0 | 0 |
27 | Locked | 40.366287 | 0 | 0 |
28 | Locked | 38.983261 | 0 | 0 |
29 | Locked | 38.983261 | 0 | 0 |
30 | Locked | 38.983261 | 0 | 0 |
31 | Locked | 38.605377 | 0 | 0 |
159 | 94 | 4K | 1840 | QAM1024 | 424 |
159 | Locked | 43 | 7.3 | 51395686 | 0 |
on 02-03-2023 09:05
I spoke to the contact team on another issue - a 24 hour total outage from 1PM Tuesday to 1PM Wednesday. The ping issue doesn't seem to have been resolved.
on 04-03-2023 15:41
Hi @Rogueywon
Thanks for coming back to the thread.
I have checked this for you today and it does seem we did have an issue with the congestion that should now be resolved.
Please let me know if you're experiencing issues still and we'll run further checks.
Best wishes.
on 16-03-2023 15:21
Unfortunately, this doesn't seem to be fixed. I'm working from home today and the ping spikes are so bad that even Teams calls are becoming disturbingly choppy.
16-03-2023 15:41 - edited 16-03-2023 15:41
According to your live BQM the problem is still there
https://www.thinkbroadband.com/broadband/monitoring/quality/share/514d6fbb54a0b2e7ef89c203f4c80b8ad480bada
It's good that @John_GS has offered you further help.
on 16-03-2023 18:06
The virgin bots are wasting your time.
Your area is congested, unless you want a 12 month battle to get them to fix it I would ask to be relieved of your contract.
P:S: They know only too well what's wrong, but its costs ££££ to fix.
16-03-2023 18:39 - edited 16-03-2023 18:41
Yes, we all know what the problem is, but a staff member has offered to help.
If it comes to a more serious complaint with the Ombudsman, it will be necessary to show that they have been given every opportunity to put it right.
@Rogueywon should keep a copy of this thread for evidence.
on 19-03-2023 14:04
Hi Rogueywon, thanks for the message and welcome back to the forums.
I am sorry to hear that there is still an issue with the service and this is not the experience which you want to have with us.
I will send you a private message so that this can be looked into further.
Please look out for the purple envelope.
Kind regards, Chris.
on 19-03-2023 14:24
Thanks for confirming. Can you do a reboot as the hub as not been rebooted for 17 days. Can you confirm following this if anything has improved?^ Chris.
19-03-2023 14:46 - edited 19-03-2023 14:47
I've rebooted the hub. It may take several days to confirm whether this has helped, as the problem is erratic. However, many previous reboots of the hub have not solved the problem.
Edit: I'm already seeing some ping spikes, so probably not fixed.
on 21-03-2023 15:02
Hi @Rogueywon
Can you post your Hub status and logs? How to do this;
• Copy/paste the data from each of the tabs as text into a 'REPLY' as opposed to 'QUICK REPLY'. Please do not include your MAC address.
Also, set up a 'Broadband Quality Monitor'. This will monitor the state of your connection and record any network dropouts etc - You can do this at https://www.thinkbroadband.com/broadband/monitoring/quality
Give it a while to gather data and then click 'Share Live graph' and paste the 'Direct Link' into the forum 🙂
