on 18-04-2023 21:18
on 19-04-2023 09:12
That sounds very like the phone is staying on the 2.5GHz band instead of the 5GHz band that allows more bandwidth. Try turning off your phone completely, then turning it on again very close to the Hub. What speed do you get then?
on 18-04-2023 22:29
It would be helpful if you could tell us
1. What are you trying to do - texts, emails, watch video ?
2, What is limited - WiFi connection, speeds, intermittent?
on 18-04-2023 23:15
Sorry should have given more info.
just installed virgin fibre broadband, all other devices on Wi-Fi speed test at around 384mbs download. speed test on Samsung gives 20.8mbs.
virgin media connect app says speed is “fast” and “limited connectivity”
on 19-04-2023 09:12
on 19-04-2023 09:20
The Samsung A12 has WiFi on the 2.4Ghz b/g/n band.
With a strong signal 50Mb/s should be possible.
on 19-04-2023 09:28
Does it not have 5GHz? Must be an old device.
19-04-2023 10:25 - edited 19-04-2023 10:28
The A12 doesn't have 5GHz. Info below from /gsmarena
NETWORK
Technology | GSM / HSPA / LTE |
2G bands | GSM 850 / 900 / 1800 / 1900 - SIM 1 & SIM 2 (dual-SIM only) |
3G bands | HSDPA 850 / 900 / 2100 |
4G bands | 1, 3, 5, 7, 8, 20, 28, 38, 40, 41 |
Speed | HSPA 42.2/5.76 Mbps, LTE Cat4 150/50 Mbps |
EDIT:-
Just found the following table for O2 Coverage Type Supported Bands & Frequencies
5G Coverage |
4G Coverage |
3G Coverage |
2G Coverage |
on 19-04-2023 10:36
Those are the mobile network frequencies. WiFi bands are not mentioned.
on 19-04-2023 10:42
Apologies for only posting the mobile bands.
Again from the gsm link, the broadband capabilities are
WLAN | Wi-Fi 802.11 b/g/n, Wi-Fi Direct |
So the A12 only supports the 2.4GHz bandwidth
on 19-04-2023 11:11
It's an on-going source of confusion. 5G mobile <> 5GHz WiFi
