AlanPearce27
  • 5
Message 1 of 5
Same speeds days after upgrading
Good evening, I’ve recently upgraded from 200mb to 500mb and have so far seen no changes in speed, I’ve tried hub restarts etc and nothing changes, when I’ve checked the downstream etc on router hub it’s a big number starting with 2, looking at other posts it seems my upgrade hasn’t been applied yet or correctly?
I’ve had a few emails confirming that it’s all activated and ready to go, even a email telling me how much my bill will be going forward and how much extra I’ll pay due to the speed increase in part way through the month.
seems a bit cheeky when I haven’t even seen the increase yet but we’ve made sure to charge me for it!
can anyone advise best way to get this sorted without spending hours on the phone?
thanks!
monkmad
  • 9
  • 7
Message 2 of 5
Re: Same speeds days after upgrading
How strange, I've upgraded to Gig connection and setup router on Thursday and am still waiting to go from my old 200Mb to 1Gb. Currently, and strangely, the speed hovers between 300-450Mb 🤔
AlanPearce27
  • 5
Message 3 of 5
I’ve just Checked mine again this morning and the router status is now much higher and I’m getting around 400-420 on my iPhone, seems mine has updated overnight! (Still a bit cheeky they charge you for a good few days before it takes effect though!)
  • 6.82K
  • 593
  • 1.79K
Message 4 of 5
Check the conf settings on the Hub. It will show what speed has been provisioned.
It's Configuration tab - Primary Downstream Service Flow - Max Traffic Rate
Note VM do not guarantee wifi speeds.  All speed tests need to be wired direct to the Hub with a Cat 6a cable.  VM prefer the test at www.samknows.com/realspeed      This site only work when the Hub is in router mode, not modem mode.
  • 6.82K
  • 593
  • 1.79K
Message 5 of 5
It's Configuration tab - Primary Downstream Service Flow - Max Traffic Rate.
If it's a VOLT upgrade, it will take up to 14 days to put through.
