trentsmith
  • 24
Message 1 of 18
SW11 - Area 21 - Slow Daytime Speed
Is forum helper who is able to see if there's congestion in SW11 (Area 21). Obviously a lot more people (including myself) are currently working from home but the connection is pretty much unusable in the day (D/L is typically 2-3Mb and upload speed is pretty close to 0). It's ok early morning/night, so i am assuming the issue is a congestion one.
As a second question, i've tried upgrading from 50Mb to 200Mb on Monday, in the faint hope this may somehow help but this hasn't been processed. How long does that usually take?
Trent
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 2 of 18
Re: SW11 - Area 21 - Slow Daytime Speed
If nothing is showing try phoning 0800 561 0061, this will tell you of more local issues that may not be affecting the area. Be aware that it isn't a manned line.
Go round all the accessible co-ax connections and ensure that they are finger tight.
If everything above is OK we need do some troubleshooting; to start with …
Can you set up a Broadband Quality Monitor (BQM) at thinkbroadband.com - this will give you an insight into what is happening with the signal at the Hub, it will take a few hours to get any kind of trend showing although you can post the link straight away.
 In the URL box paste the link you copied and then click OK - you can post the link straight away.
Then
Can you please
When the page appears DO NOT LOG IN but click ‘Check Router Status’.
Copy and paste the contents of each tab onto here, if you get a yellow warning click Post again.
Paul_86
  • 173
  • 47
  • 56
Message 3 of 18
Hi Trent
Have you tried logging into the hub and resetting it?
To do this look at the bottom of the hub,
IP address is 192.168.0.1
Your IP settings password
You should then be into the GUI on the hub
Select Admin
Reload and reboot
Click restore default
Once the hub has reset give it another speed test hopefully that should resolve the issue for you.
Let me know how you get on.
Paul
trentsmith
  • 24
Message 4 of 18
Hi Paul,
I have tried rebooting the hub a couple of times over the past few days but it doesn't seem to help. The speed isn't always slow, if it's early or late, i can get full speed.
Trent
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 5 of 18
Are you going to set up a BQM and post your Hub data on here ?
trentsmith
  • 24
Message 6 of 18
Hi Mike,
Thanks for the response. The service status showed a problem on Monday (when it first became slow) but it then said that was resolved Monday afternoon. It doesn't seemed to have helped my issue though. The connection tightness seems ok. I am now working of my phone hotspot, so i'd need to try the BQM link on the weekend. I've logged back on though, and copied the router status below.
PS - Any idea how long the speed change to 200Mb should take?
Trent
Information
Cable ModemEuroDOCSIS 3.0 Compliant
Serial Number48314CW71347B
Boot Code VersionPSPU-Boot 1.0.20.1391
Software VersionV2.01.15
Hardware Version1.03
CA KeyInstalled
Acquired Downstream Channel (Hz)138750000Locked
Ranged Upstream Channel (Hz)53700000Success
Provisioning StateOKOperational
Downstream  DS-1 DS-2 DS-3 DS-4 DS-5 DS-6 DS-7 DS-8
Frequency (Hz)138750000146750000154750000162750000170750000178750000186750000194750000
Lock Status(QAM Lock/FEC Sync/MPEG Lock)LockedLockedLockedLockedLockedLockedLockedLocked
Channel ID12345678
Modulation256QAM256QAM256QAM256QAM256QAM256QAM256QAM256QAM
Symbol Rate (Msym/sec)6.9520006.9520006.9520006.9520006.9520006.9520006.9520006.952000
Interleave DepthI=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
Power Level (dBmV)-2.71-2.74-3.19-3.03-2.97-3.23-3.24-3.43
RxMER (dB)36.3936.8436.1736.3937.0937.0937.0937.09
Pre RS Errors40932644474642297303291302
Post RS Errors290309296287292290277
286
Upstream  US-1 US-2 US-3 US-4
Channel Type2.02.02.02.0
Channel ID2341
Frequency (Hz)53700000462000003940000060300000
Ranging StatusSuccessSuccessSuccessSuccess
Modulation64QAM64QAM64QAM64QAM
Symbol Rate (Sym/sec)5120000512000051200005120000
Mini-Slot Size2222
Power Level (dBmV)51.0051.0051.0051.00
T1 Timeouts0000
T2 Timeouts0000
T3 Timeouts1000
T4 Timeouts0000
Upstream Burst  Req(1) Init Maint(3) Per Maint(4) Adv Short(9) Adv Long(10) Adv UGS(11)
Modulation Type16QAMQPSK16QAM64QAM64QAM16QAM
Differential EncodingOFFOFFOFFOFFOFFOFF
Preamble Length56640384104104104
Preamble Value Offset65200716716716
FEC Error Correction (T)05510165
FEC Codeword Information Bytes (K)1634348122386
Maximum Burst Size0003255255
Guard Time Size84848888
Last Codeword LengthFixedFixedFixedShortenedShortenedShortened
Scrambler On/OffONONONONONON
General Configuration
Network AccessAllowed
Maximum Number of CPEs1
Baseline PrivacyEnabled
DOCSIS ModeEuroDOCSIS 3.0
Config File
SFID623536
Max Traffic Rate57344000 bps
Max Traffic Burst10000 bytes
Min Traffic Rate0 bps
Primary Upstream Service Flow
SFID623535
Max Traffic Rate5250045 bps
Max Traffic Burst16320 bytes
Max Concatenated Burst16320 bytes
Scheduling TypeBest Effort
trentsmith
  • 24
Message 7 of 18
https://www.thinkbroadband.com/broadband/monitoring/quality/share/201ae6c79001f2dc18cf107a7dd8359dd2...
This is the link the the BQM. At the moment, it actually seems to be working ok.
Trent
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 8 of 18
Are you in Modem mode with a router or just Modem mode ?
trentsmith
  • 24
Message 9 of 18
I am in the usual mode, the only device is the Superhub which is doing the router function and wifi.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 10 of 18
It is showing 100% packet loss.
Can you view bbc.co.uk ?
