SPEED ISSUES
New user so here goes –
I'm having speed problems. I've got Virgin’s 100Mbps broadband package and am using a Superhub3 (with Virgin’s wifi extender) . However, my speed, especially via wifi is poor.
I'm getting Download 40.46 and Upload 9.9 via direct Ethernet and
Download 10.8 and Upload 6.09 via wifi.
Is this correct (all I should be getting) or am I right doubting?
Cheers David
Channel          Frequency (Hz)           Power (dBmV)           SNR (dB)        Modulation            Channel ID
1          323000000     5.5       40        256 qam         24
2          139000000     4          38        256 qam         1
3          147000000     4          38        256 qam         2
4          155000000     4          38        256 qam         3
5          163000000     4.3       38        256 qam         4
6          171000000     4.4       38        256 qam         5
7          179000000     4.4       38        256 qam         6
8          187000000     4          38        256 qam         7
9          195000000     4.6       38        256 qam         8
10        203000000     5          38        256 qam         9
11        211000000     5          38        256 qam         10
12        219000000     5.3       38        256 qam         11
13        227000000     5.3       40        256 qam         12
14        235000000     5.4       40        256 qam         13
15        243000000     5.5       40        256 qam         14
16        251000000     5.5       40        256 qam         15
17        259000000     5.6       40        256 qam         16
18        267000000     5.6       40        256 qam         17
19        275000000     5.5       40        256 qam         18
20        283000000     5.5       40        256 qam         19
21        291000000     5.6       38        256 qam         20
22        299000000     5.6       38        256 qam         21
23        307000000     5.6       40        256 qam         22
24        315000000     5.5       40        256 qam         23
Channel          Locked Status RxMER (dB)  Pre RS Errors Post RS Errors
1          Locked            40.3     852      1988
2          Locked            38.6     1036    2558
3          Locked            38.9     1183    3305
4          Locked            38.9     1376    3307
5          Locked            38.9     3981    6467
6          Locked            38.9     1803    4424
7          Locked            38.9     1855    4633
8          Locked            38.9     1654    7725
9          Locked            38.9     1699    5408
10        Locked            38.9     1633    5183
11        Locked            38.9     330      6718
12        Locked            38.9     182      7283
13        Locked            40.3     197      7212
14        Locked            40.3     240      7310
15        Locked            40.3     254      7044
16        Locked            40.3     230      7378
17        Locked            40.3     227      7092
18        Locked            40.3     235      7628
19        Locked            40.3     224      7338
20        Locked            40.3     231      7282
21        Locked            38.9     258      7657
22        Locked            38.9     3416    7060
23        Locked            40.3     753      3245
24        Locked            40.3     2142    3392
Channel          Frequency (Hz)           Power (dBmV)           Symbol Rate (ksps)    Modulation            Channel ID
1          32600021       3.875   5120    64 qam           5
2          53699999       4          5120    64 qam           2
3          39399911       3.9       5120    64 qam           4
4          46199994       3.95     5120    64 qam           3
Channel          Channel Type T1 Timeouts   T2 Timeouts   T3 Timeouts   T4 Timeouts
1          ATDMA         0          0          0          0
2          ATDMA         0          0          0          0
3          ATDMA         0          0          0          0
4          ATDMA         0          0          0          0
Time    Priority           Description
22/11/2019 10:05:15  critical SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/11/2019 10:05:19  Warning!        Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/11/2019 10:07:7    critical SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/11/2019 10:07:7    Warning!        RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/11/2019 10:07:12  Warning!        Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/11/2019 10:07:58  Warning!        RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/11/2019 12:48:29  critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
26/11/2019 12:35:56  Error   DHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
27/11/2019 05:46:54  critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
27/11/2019 08:51:47  Error   DHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
27/11/2019 15:37:7    Error   DHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
27/11/2019 20:11:14  critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/12/2019 06:11:1    Error   DHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/12/2019 05:47:36  Error   DHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
06/12/2019 07:17:54  Error   DHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
07/12/2019 09:21:49  critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
07/12/2019 09:28:32  Error   DHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
07/12/2019 09:53:30  Error   DHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/12/2019 12:25:18  critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
  • 4.4K
  • 744
  • 1.78K
Re: SPEED ISSUES
Over ethernet you should normally get every bit-per-second that you're paying for (when it works, VM is good like that).  Over wifi things are different, and is strikes me that you've got a wifi configuration problem AND a poor cable connection.  The network log shows that your hub is struggling in getting and maintaining a fast connection (those RCS Partial Service and No Ranging Response errors should not be occurring repeatedly and frequently).
You need to treat the wifi speed issue separately to the cable fault, because with wifi problems customers are on their own - VM issue the manky old Hub 3, and say "there you go, your problem to get it working right".  These forums can and will help, but probably best to focus on sorting out the wired connection speed.  Read this as a possible way forward.
