Grindathotte
  • 14
Message 1 of 7
SLow speed with interruptions on M350
When I first upgraded to M350, I was getting this speed and above most of the time.  I have not seen anything above 200 Mb for weeks and I am getting frequent interruptions, which causes drop-outs in online meetings.
Downstream bonded channelsChannel Frequency (Hz) Power (dBmV) SNR (dB) Modulation Channel ID
11387500003.737256 qam1
21467500004.137256 qam2
31547500004.538256 qam3
41627500004.938256 qam4
5170750000538256 qam5
6178750000538256 qam6
71867500004.938256 qam7
81947500004.938256 qam8
92027500004.638256 qam9
102107500004.638256 qam10
112187500004.838256 qam11
122267500004.938256 qam12
132347500004.938256 qam13
142427500004.638256 qam14
152507500004.538256 qam15
162587500004.538256 qam16
172667500004.938256 qam17
182747500004.938256 qam18
192827500005.138256 qam19
20290750000538256 qam20
212987500005.538256 qam21
22306750000538256 qam22
233147500005.338256 qam23
24322750000538256 qam24
1Locked37.610839634035995707
2Locked37.6148805772622424
3Locked38.62165570719654
4Locked38.62089952568512
5Locked38.92013337479193
6Locked38.61915769392429
7Locked38.61888222336209
8Locked38.91802886262924
9Locked38.91680931189528
10Locked38.61579469129360
11Locked38.9142000281926
12Locked38.6129737057157
13Locked38.6118977541096
14Locked38.6108109843985
15Locked38.696142846687
16Locked38.992025648146
17Locked38.676753924683
18Locked38.668304114160
19Locked38.658353210158
20Locked38.65844949296
21Locked38.64638354799
22Locked38.64753364015
23Locked38.64067162145
24Locked38.64318502349
Grindathotte
  • 14
Message 2 of 7
Re: SLow speed with interruptions on M350
Upstream bonded channelsChannel Frequency (Hz) Power (dBmV) Symbol Rate (ksps) Modulation Channel ID
1325999754.6512064 qam7
2394001174.675512064 qam6
3462000004.725512064 qam5
4258000054.6512064 qam8
Upstream bonded channelsChannel Channel Type T1 Timeouts T2 Timeouts T3 Timeouts T4 Timeouts
3ATDMA0000
4ATDMA0000
29/10/2020 10:59:37criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
28/10/2020 14:09:5Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
27/10/2020 23:03:20criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
27/10/2020 17:10:15Warning!LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
27/10/2020 12:28:45criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
25/10/2020 22:08:53criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
25/10/2020 20:48:39criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
25/10/2020 19:24:30criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
25/10/2020 18:30:20ErrorDHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
25/10/2020 13:34:58ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
25/10/2020 09:32:0criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
25/10/2020 08:39:39ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
25/10/2020 00:37:58criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/10/2020 22:49:2ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
23/10/2020 12:53:2criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
23/10/2020 12:39:21criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
23/10/2020 11:51:53Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
23/10/2020 03:39:25criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/10/2020 04:00:24criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/10/2020 22:37:48ErrorDHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 3 of 7
If nothing is showing try phoning 0800 561 0061, this will tell you of more local issues that may be affecting your district. Be aware that it isn't a manned line.
Go round all the accessible internal and external co-ax connections and ensure that they are finger tight.
Your Pre & Post RS Error counts are very high.
In an ideal world they would be at zero and stay there. To zero them can you reboot the Hub using this method and then keep an eye on the counts.
Switch the Hub off using the small switch on the rear of the Hub next to the power cord and pull the PSU plug from the wall socket.
Give it a good 5 minutes put the plug back in and switch the Hub back on.
Allow the Hub a few minutes to fully restart then the counts again.
Martin_N
  • 5.55K
  • 232
  • 317
Message 4 of 7
Hi Grindathotte,
Thank you for your post and welcome to the community.
I'm very sorry to hear about the slow speed issue you're having.
I have taken a look on our side this does need further investigation.
To assist with this I will private message you to get some details.
^Martin
Katie_WT
  • 5.02K
  • 304
  • 569
Message 5 of 7
Hi there @Grindathotte
Thanks so much for your Private Messages to @Martin_N; sorry to understand that you're having some issues with your broadband and having some slower speeds than expected.
After having a look at your account from this end, I can see that you rebooted around 10 hours ago. We have no known area issues showing at the time of writing today and also no errors showing on your Hub.
All signal levels are well within the parameters we would expect for your package.
Have you been able to do the BQM as suggested by our user @MikeRobbo so we can see if the drop outs are showing there at all?
I do see that you are currently using the Hub in Modem mode; do you have the same issue if you have the Hub in Router mode?
Please do pop back when you can and keep us posted.
Cheers
Katie - Forum Team
Grindathotte
  • 14
Message 6 of 7
Thanks to all who have taken the time to answer.  It does not appear to have been so bad lately and as I have been very busy with work, I have not really had a chance to follow it up.  For some reason, when I check the speed with fast.com, it shows less than 200 Mbs for the first few times, then goes up to 350 and sometimes higher.  I did note that when transferring large files by ftp from work, I was getting speeds approaching 350, so maybe the problem has cleared.  Thanks to your responses, I have a line of action to pursue if further problems occur.
Graham.
Katie_WT
  • 5.02K
  • 304
  • 569
Message 7 of 7
Thanks so much for the update Graham (@Grindathotte)
Feel free to pop back anytime if you have further issues and we'll be happy to do further checks with you.
Have a good week and stay safe
Cheers
Katie - Forum Team
