jv87
  • 11
SLOW SPEED
I’m paying for 100 lol
Christy_D
  • 1.06K
  • 144
  • 164
Re: SLOW SPEED
Good Evening
Thanks for your post and welcome to the community
May I ask if you are running the speed tests wired or over wifi?
Christy
jv87
  • 11
Re: SLOW SPEED
It was WiFi
Andruser
  • 5.53K
  • 970
  • 2.28K
Re: SLOW SPEED
I suspect a broadband problem. Connect to the hub by clicking on this link http://192.168.0.1/  That should pull up the log in page for the hub.  But don't log in, just click on the link "Check router status"  That'll bring up a window with five tabs.  Open the Downstream tab.  Select all the text (Ctrl-A if using a keyboard), copy it (Ctrl-C), then paste it (Ctrl-V) into a reply here as text (not screenshots).  Post that, do the same for the Upstream and Network log.  You'll get an error message when you post the Network log, just click on "post" a second time.
Then we can check for any obvious problems with power, noise or error counts.
