noobhands
  • 6
Message 1 of 15
SG4 - 500MB - Consistently slow speed for weeks
I'm on the 500MB package, I've not had anything close to that since covid19 (I understand - there's more load with people WFH). However it seems even at non-peak times, the speed is only hitting 250MB max...
I've called in before, and it was reported an issue in the area (service status didn't display this), I was told to wait til 6pm on Friday, and to then see how things were... It's been exactly the same.
Here's a speedtest which seems long ago for when I used to get decent speeds...
I've also noticed that you're giving a boost to everyone, is this at the expense of those who are paying for 500MB? I've got my renewal up in May and it's not looking great in terms of speed.
Anonymous
Not applicable
Message 2 of 15
Re: SG4 - 500MB - Consistently slow speed for weeks
"however it seems even at non-peak times, the speed is only hitting 250MB max..."
Not really such a thing as non peak ties right now
SCA1972
  • 5.77K
  • 654
  • 1.93K
Message 3 of 15
Have you got any speed tests from after midnight or before 7am on a weekday?  Those are the new off peak times since lockdown started.
Issues with peak time utilization have never appeared on the service status page, that is seemingly reserved for outages not slowdowns.
______________________
Scott
My setup: V6 TV box, M350 Fibre broadband with Hub 3 in modem mode connected to a Netgear R7000 router. Telewest/VM user since 2001.
noobhands
  • 6
Message 4 of 15
Here are ones lately close to those times.
gary_dexter
  • 30.32K
  • 1.88K
  • 4.03K
Message 5 of 15
You need to run speed tests when wired not over wireless
noobhands
  • 6
Message 6 of 15
I am connected via ethernet.
The wireless looking logo is 'multi connection' on speedtest, but thanks anyway.
gary_dexter
  • 30.32K
  • 1.88K
  • 4.03K
Message 7 of 15
Disable the WiFi and run a wired connection.
Multi-connections means the number of threads used for the test and the icon is either a single arrow or three arrows.
https://help.speedtest.net/hc/en-us/articles/360038679354-How-does-Speedtest-measure-my-network-spee...
The WiFi symbol you’re showing means it’s a wifi test - a wired test will show a picture of a PC and has the icon name of “Web”.
noobhands
  • 6
Message 8 of 15
No - I'm on my desktop PC, I don't have a wireless card.
gary_dexter
  • 30.32K
  • 1.88K
  • 4.03K
Message 9 of 15
Then it should show an icon of a PC and not a wifi logo.
Just tested this to confirm myself.
noobhands
  • 6
Message 10 of 15
Clearly you know my desktop specs better than me then...
I'd like you show me the wifi card I have somehow plugged in and connected to my wifi to produce these speedtest results?
I've just done a speedtest via my desktop,
Unless you care to show me otherwise?
