Drod
SFTP upload speed
Dear Forum,
Due to the norm, I have to use SFTP to transfer data from/to my PC. My upload speed is too slow, and probably and getting the penalties of uploading too much data. Is there any way I can increase my upload speed?
Tags (1)
Anonymous
Not applicable
Re: SFTP upload speed
only by upgrading your package.
What speed are you seeing ands what package are you on
Drod
Hi apcyberax,
Going through some of the posts, I think I made a mistake on what my upload speed is. I am getting confused between MB/s (as it is given by the sftp client) and the speed test given on Mbps. At the moment I am uploading at 1 MB/s and my plan quotes 10Mbps. 1MB/s -> 8Mbs isn't it? Which it is close to the max. speed.
Drod
Tags (1)
DJ_Shadow1966
  • 6.85K
  • 1.31K
  • 1.89K
Hello
Yes 1Mb/s is 8mb/s so you are getting close to your upload speed, when uploading it will not flood the upload to your connection as doing  so would limit the download as to get info downloaded you need a small amount of upload to send acknowledgement signals.
Regards Mike
