Spendrey
Routing and performance issues
Has anyone else (in the Swindon area?) had issues this week?  I've been getting 70 instead of 100Mb for a few days, today I'm barely getting 50.
I also note that I can't access some websites (eurocarparts.com) for example, whereas I can over 4G.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Re: Routing and performance issues
Can you Login to the Hub Settings and navigate to the Connected Devices page - what does it report the 'connection speed’ as for the cable connected device you used for the speed test ?
Spendrey
I'm using a 1Gb wired connection.  Now, the home network is complicated, but I can't see that being the issue here.
I'm using the Hub3 as a modem, GbE to an Asus router, then GbE again to a switch to which I'm connected at 10Gb 🙂
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Let's start again ...
What speed do you get at >> Sam Knows Real Speed << with a direct connection using a Cat 5E/6 cable between the Hub in Router Mode and a 1Gbs capable Pc/Mac/Chromebook and no other devices connected ?
Spendrey
Switching back to the Hub3 in router mode does indeed improve the situation re. performance.  It would seem the Asus router/Hub 3 modem pairing doesn't work so well (even if it claims GbE).
Still had routing issues for another 24 hours (to specific sites), although DNS was resolving them correctly... that's cleared up too now.
Now, if only I could get MAC Filtering to work properly on the Hub3, that was the reason for using the Asus router!
cje85
  • 2.66K
  • 170
  • 700
Trouble shooter
The ASUS router should be fine. I use an ASUS RT-AC86U with the Hub 3 and haven't had any problems.
As router mode gives you a different IP, perhaps the previous IP you had in modem mode was blocked for some reason. IP blocking seems to be a common issue on VM.
