dehumphrey
Message 1 of 8
Reporting a Broadband Fault
My hub 4 is showing the following
While service status says everything is OK. Clearly not the case. I have rebooted the hub and checked the RF cable connections are tight.
I cannot find any way of reporting this to get the issue resolved. Does anyone know of a way to report a fault?
Thanks in advance for any help.
Dave
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 2 of 8
Re: Reporting a Broadband Fault
Without seeing the image (that needs to be authorised) it is impossible to advise.
Could you put the image onto a hosting site and link to the image that way; or give us a simple explanation of the problem.
dehumphrey
Message 3 of 8
Sorry, the image shows the modem admin page showing "No RF signal detected" against the Internet on the status page, hence the checking the RF cable connections. VM say there is no fault in my area so I needx to report the issue somehow.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 4 of 8
Can you please try this ...
When the page appears DO NOT LOG IN but click ‘Check Router Status’.
Copy and paste the contents of the Downstream, Upstream and Network Log tabs onto here, if you get a yellow warning click the Post button again.
dehumphrey
Message 5 of 8
Interesting trying to get to router status without logging in producing a blank page. If I login I get the following from the network log:
CM-STATUS message sent. Event Type Code: 2; Chan ID: 1; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Status shows as offline
I hope this helps.
Cheers
Dave
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 6 of 8
dehumphrey
Message 7 of 8
Cable Modem StatusItemStatusCommentsCable Modem Status
Offline
DOCSIS unknown
Primary downstream channel
NotLocked
0
Channel OverviewDownstreamUpstreamDOCSIS 3.0 channels
7
0
DOCSIS 3.1 channels
0
0
Refresh data
3.0 Downstream channels
0 842500000 -51.099998 21.536777 UNSUPPORTED 0
0 842000000 -52.099998 4.967847 UNSUPPORTED 0
0 843250000 -52.599998 11.932404 UNSUPPORTED 0
0 847500000 -52.200001 6.130963 UNSUPPORTED 0
0 854000000 -51.099998 15.343725 UNSUPPORTED 0
0 852500000 -52.200001 19.034893 UNSUPPORTED 0
0
0
0 NotLocked 0 0 4069
0 NotLocked 0 0 4056
0 NotLocked 0 0 3769
0 NotLocked 0 0 2628
0 NotLocked 0 0 2848
0 NotLocked 0 0 2276
0
0 0 0
Refresh data
3.0 Upstream channels
1
1
0 0 0 0
Refresh data
Mon 17/08/2020 12:46:51 3 SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Mon 17/08/2020 12:49:54 5 MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Mon 17/08/2020 12:50:01 3 No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Mon 17/08/2020 16:33:15 3 SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Mon 17/08/2020 16:33:18 3 No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Mon 17/08/2020 16:33:23 3 SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Mon 17/08/2020 16:33:24 6 CM-STATUS message sent. Event Type Code: 2; Chan ID: 2; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Mon 17/08/2020 16:33:25 3 SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Mon 17/08/2020 16:33:28 5 Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Mon 17/08/2020 16:33:30 3 SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Mon 17/08/2020 16:33:36 3 No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Mon 17/08/2020 16:33:37 3 SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Mon 17/08/2020 16:33:37 6 CM-STATUS message sent. Event Type Code: 1; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Mon 17/08/2020 16:33:38 3 SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Mon 17/08/2020 16:33:44 3 No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Mon 17/08/2020 16:33:45 3 SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Mon 17/08/2020 16:33:48 3 No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Mon 17/08/2020 16:33:50 3 SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Mon 17/08/2020 16:33:54 6 CM-STATUS message sent. Event Type Code: 4; Chan ID: 2; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Mon 17/08/2020 16:33:56 3 No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Mon 17/08/2020 16:33:58 6 CM-STATUS message sent. Event Type Code: 5; Chan ID: 1; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Mon 17/08/2020 16:34:15 3 SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Mon 17/08/2020 16:34:17 6 CM-STATUS message sent. Event Type Code: 2; Chan ID: 12; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Mon 17/08/2020 16:34:19 3 SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Mon 17/08/2020 16:34:21 6 CM-STATUS message sent. Event Type Code: 2; Chan ID: 1; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Mon 17/08/2020 16:34:24 5 Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Mon 17/08/2020 16:34:37 3 No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Mon 17/08/2020 16:34:38 3 SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Mon 17/08/2020 16:34:42 5 Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Mon 17/08/2020 16:34:59 3 No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Mon 17/08/2020 16:35:01 5 Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Mon 17/08/2020 16:35:02 3 No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Mon 17/08/2020 16:35:03 6 CM-STATUS message sent. Event Type Code: 4; Chan ID: 3; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
John_GS
  • 8.71K
  • 476
  • 769
Message 8 of 8
Hi dehumphrey
My apologies for the delayed reply and also the broadband issue.
I've not been able to locate your account from the Forum information provided. I do hope everything is resolved for you, however if not, let me know and I'll more than happily assist further.
Kind regards,
John_GS
