keymaster_
  • 17
Message 1 of 15
Regular internet drops and occasional speed issues
For the last month or so, I've been getting regular internet dropouts during the day, around once or twice a day, for a few minutes each time. In the past it seemed like big downloads can trigger it reliably. Additionally, sometime around 00:30 the internet drops every night.
The drop usually causes me to lose internet, then my PC disconnects from WiFi, and when I reconnect to the network it takes a few minutes until it gets internet again. While this happens the hub has the usual white light at the front, so it doesn't look like it's restarting.
Additionally, I seem to be getting unreliable speeds, between 10 and 100 mpbs (on a 100 connection). I haven't spotted any patterns with it yet.
This is all after I had a technician swap my hub and check the whole span of my connection very recently, so WiFi and cables should not be an issue.
gary_dexter
  • 30.32K
  • 1.88K
  • 4.03K
Message 2 of 15
Re: Regular internet drops and occasional speed issues
What are wired device connections and speeds like?
Wifi is not covered under the speed guarantee so not much can be done other than getting your own (better) equipment to extend and optimise your WiFi.
keymaster_
  • 17
Message 3 of 15
Since I can get good speeds on wifi at times (just checked and got the full 100 at this moment), so wifi strength is not the issue.
The bigger issue are the regular dropouts, which to my understanding would not be wifi related, since I can still connect to the network at those times, I just get no internet.
I can't test wired connections without buying some adapters, and having a wired connection for my day-to-day work isn't possible due to the layout of my flat.
gary_dexter
  • 30.32K
  • 1.88K
  • 4.03K
Message 4 of 15
Then it’s impossible to ascertain if it is just a WiFi issue or a connection issue as a whole.
Post the Network, Upstream and Downstream logs from the hub admin page
keymaster_
  • 17
Message 5 of 15
Hope this helps.
Network Log:
TimePriorityDescription
21/06/2020 21:37:55Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;</td
21/06/2020 21:37:55Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;</td
21/06/2020 21:36:46Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;</td
21/06/2020 21:36:45notice LANogin Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;</td
21/06/2020 21:36:39Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;</td
21/06/2020 21:36:37Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;</td
21/06/2020 21:36:15Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;</td
21/06/2020 21:36:14Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;</td
21/06/2020 21:35:18Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;</td
21/06/2020 21:35:17Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;</td
21/06/2020 21:34:38Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;</td
21/06/2020 21:34:37Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;</td
21/06/2020 21:33:59Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;</td
21/06/2020 21:33:59Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;</td
21/06/2020 21:33:30Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;</td
21/06/2020 21:33:30Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;</td
21/06/2020 21:31:21Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;</td
21/06/2020 21:31:21Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;</td
21/06/2020 21:30:35Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;</td
21/06/2020 21:30:35Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;</td
ChannelFrequency (Hz)Power (dBmV)Symbol Rate (ksps)ModulationChannel ID
1393999564.425512064 qam4
2462000004.45512064 qam3
3326000004.4512064 qam5
4257999764.375512032 qam6
ChannelChannel TypeT1 TimeoutsT2 TimeoutsT3 TimeoutsT4 Timeouts
3ATDMA0000
4ATDMA0000
11870000005.340256 qam7
21950000004.940256 qam8
32110000004.140256 qam10
42350000004.440256 qam13
5243000000440256 qam14
62510000004.340256 qam15
72590000004.140256 qam16
82670000003.940256 qam17
92750000003.740256 qam18
10283000000440256 qam19
112910000003.740256 qam20
122990000003.240256 qam21
133070000003.540256 qam22
143150000003.540256 qam23
153230000002.940256 qam24
163790000003.740256 qam25
173870000003.540256 qam26
183950000003.738256 qam27
194030000003.740256 qam28
204110000003.240256 qam29
214190000003.438256 qam30
1Locked40.92080
2Locked40.37560
3Locked40.3120610
4Locked40.3990
5Locked40.9470
6Locked40.3950
7Locked40.9740
8Locked40.91330
9Locked40.913410
10Locked40.3370
11Locked40.3520
12Locked40.3790
13Locked40.33180
14Locked40.32290
15Locked40.32950
16Locked40.3104425224
17Locked40.96810
18Locked38.92500
19Locked40.31990
20Locked40.35166483
21Locked38.61060
gary_dexter
  • 30.32K
  • 1.88K
  • 4.03K
Message 6 of 15
There’s some noise on some of the downstream channels shown by the Post-RS count - when was the hub last rebooted?
keymaster_
  • 17
Message 7 of 15
Might have been a week or two since the last reboot. In the past it hasn't helped any issues, but I can try again.
I'd hope that I don't have to reboot this thing every few days 😕
gary_dexter
  • 30.32K
  • 1.88K
  • 4.03K
Message 8 of 15
Reboot then post the same logs in a minimum of 1 hours time to see what the Pre and Post RS numbers show
keymaster_
  • 17
Message 9 of 15
Rebooted now, should have time to grab the new logs tomorrow. Thanks for the help so far 🙂
keymaster_
  • 17
Message 10 of 15
Posting only the network and downstream logs to save some time, lmk in case the other ones are also needed. They look pretty much the same as last time though.
Network log
22/06/2020 09:47:23Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/06/2020 09:47:22Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/06/2020 09:47:22Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/06/2020 09:47:21noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/06/2020 09:46:32Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/06/2020 09:46:32Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/06/2020 09:45:53Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/06/2020 09:45:52Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/06/2020 09:45:40Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/06/2020 09:45:40Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/06/2020 09:45:33Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/06/2020 09:45:32Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/06/2020 09:45:17Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/06/2020 09:45:15Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/06/2020 09:45:5Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/06/2020 09:45:4Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/06/2020 09:44:57Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/06/2020 09:44:56Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/06/2020 09:44:30Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/06/2020 09:44:28Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
Downstream Bonded Channels
1Locked40.94650
2Locked40.36440
3Locked40.91144122
4Locked40.92670
5Locked40.32530
6Locked40.91840
7Locked40.93130
8Locked40.91790
9Locked40.92002
10Locked40.91710
11Locked40.31880
12Locked40.31880
13Locked40.33070
14Locked40.32750
15Locked40.92790
16Locked40.35232924
17Locked40.34020
18Locked38.94200
19Locked40.94330
20Locked40.357877
21Locked38.95790
