AlexStephens
  • 5
Message 1 of 5
Regular dropouts and slow speeds
im on m200. I get regular dropouts and slow speeds. Router is on ground floor hub 3.0. Two boosters help with connectivity in house but even when I connect direct I get slow speeds and regular dropouts.
help please
Alex
AlexStephens
  • 5
Message 2 of 5
Re: Regular dropouts and slow speeds
139000000
Locked
Ranged Upstream Channel (Hz)
46200000
Locked
Provisioning State
Online
11390000005.138256 qam1
21470000005.338256 qam2
31550000005.438256 qam3
41630000005.438256 qam4
51710000005.638256 qam5
61790000005.538256 qam6
71870000005.538256 qam7
81950000005.538256 qam8
92030000005.138256 qam9
102110000004.938256 qam10
112190000004.838256 qam11
122270000004.538256 qam12
132350000004.538256 qam13
142430000004.138256 qam14
152510000004.138256 qam15
162590000004.138256 qam16
172670000004.638256 qam17
18275000000538256 qam18
19283000000538256 qam19
202910000005.138256 qam20
212990000005.538256 qam21
223070000005.938256 qam22
23315000000638256 qam23
24323000000638256 qam24
1Locked38.650
2Locked38.660
3Locked38.650
4Locked38.650
5Locked38.940
6Locked38.650
7Locked38.950
8Locked38.940
9Locked38.960
10Locked38.960
11Locked38.960
12Locked38.650
13Locked38.690
14Locked38.680
15Locked38.960
16Locked38.900
17Locked38.940
18Locked38.950
19Locked38.950
20Locked38.650
21Locked38.960
22Locked38.650
23Locked38.970
24Locked38.650
AlexStephens
  • 5
Message 3 of 5
1462000004.775512064 qam3
2394000004.75512064 qam4
3258000384.75512064 qam6
4326000004.75512064 qam5
3ATDMA0000
4ATDMA0000
03/09/2020 15:16:21noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
03/09/2020 15:13:28Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
03/09/2020 15:08:21criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
03/09/2020 15:04:13criticalReceived Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
03/09/2020 15:01:18Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
03/09/2020 15:01:14criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
03/09/2020 15:01:13Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
03/09/2020 15:01:13criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
03/09/2020 14:54:49Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
03/09/2020 14:54:49criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
03/09/2020 14:54:48Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
03/09/2020 14:54:48criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
03/09/2020 14:53:49Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
03/09/2020 14:53:45criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
03/09/2020 14:53:44Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
03/09/2020 14:53:44criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
03/09/2020 14:51:23Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
03/09/2020 14:51:23criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
AlexStephens
  • 5
Message 4 of 5
General Configuration
Network access
Allowed
Maximum Number of CPEs
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
cmreg-vmdg505-rtsxl20016u+voc-b.cm
SFID1289060
Max Traffic Rate230000061
Max Traffic Burst42600
Min Traffic Rate0
Primary Upstream Service Flow
SFID1289059
Max Traffic Rate22000061
Min Traffic Rate0
Max Concatenated Burst42600
Scheduling TypeBestEffort
AlexStephens
  • 5
Message 5 of 5
