Muh4mm3d
  • 39
Message 1 of 38
Reduced Download Speed
So today i noticed that my download was also slower than few days last time. Last i checked my speed was got excatly what i am paying for but now it was low and here are the speedtest result. also im testing this on a wired connection on my pc.Speedtest.png
Anonymous
Not applicable
Message 2 of 38
Re: Reduced Download Speed
Could you access your router using http://192.168.0.1/ or http://192.168.100.1 for modem mode . You shouldn't need log in, select the 'Check Router Status' option and paste your 'Downstream', 'Upstream', and 'Network Log' tabs? Please copy/paste this data as text, split between multiple posts (Sometimes you have to click 'Post' twice due to an error message).
Could you please create a BQM (Broadband Quality Monitor) here, and post the live link?
Muh4mm3d
  • 39
Message 3 of 38
Downstream:
1139000000738256 qam1
2147000000738256 qam2
31550000006.338256 qam3
4163000000638256 qam4
5171000000638256 qam5
61790000005.938256 qam6
7187000000638256 qam7
81950000005.838256 qam8
9203000000638256 qam9
102110000006.338256 qam10
112190000006.338256 qam11
12227000000638256 qam12
13235000000638256 qam13
142430000005.538256 qam14
152510000006.538256 qam15
162590000006.938256 qam16
172670000006.638256 qam17
182750000006.438256 qam18
192830000006.438256 qam19
202910000006.438256 qam20
212990000006.838256 qam21
223070000006.538256 qam22
23315000000738256 qam23
243230000006.938256 qam24
1Locked38.6310
2Locked38.6290
3Locked38.9410
4Locked38.6510
5Locked38.9260
6Locked38.9420
7Locked38.9400
8Locked38.9290
9Locked38.6110
10Locked38.6140
11Locked38.6150
12Locked38.9330
13Locked38.6210
14Locked38.9150
15Locked38.9160
16Locked38.9150
17Locked38.9240
18Locked38.9200
19Locked38.9240
20Locked38.6200
21Locked38.9450
22Locked38.6170
23Locked38.9390
24Locked38.9300
Upstream:
14619993839.5512064 qam1
22580008838.5512064 qam4
33939997538.5512064 qam2
43260000038.5512064 qam3
3ATDMA0000
4ATDMA0010
BQM:
https://www.thinkbroadband.com/_assets/speedtest/button/1605034711519916355.png
Anonymous
Not applicable
Message 4 of 38
That's a speed test, not a BQM.
Have you tested on a wired device?
Muh4mm3d
  • 39
Message 5 of 38
Yes its on wired sorry.
heres the BQM
https://www.thinkbroadband.com/broadband/monitoring/quality/share/3b7e246e16447023cf640df24f55a648bafd9ed5-10-11-2020
Muh4mm3d
  • 39
Message 6 of 38
So now what? the download speed is still slow compared to what i was promised and what i used to get for a few days?
Anonymous
Not applicable
Message 7 of 38
Can you post the live BQM link (The one you lined to is from 10/11)?
Muh4mm3d
  • 39
Message 8 of 38
https://www.thinkbroadband.com/broadband/monitoring/quality/share/d2e17f240cbbf6ada1e662c9d87ce673011cd515
Muh4mm3d
  • 39
Message 9 of 38
Anonymous
Not applicable
Message 10 of 38
@Muh4mm3d wrote:
https://www.thinkbroadband.com/broadband/monitoring/quality/share/d2e17f240cbbf6ada1e662c9d87ce67301...
 is this the correct link?
Yes. Your BQM doesn't actually look too bad, there was an outage (Not sure if you turned off the HUB?).
Could you confirm you have tested on a wired connection as the speedtests above are on wireless?
