MarkyB52
  • 9
Message 1 of 9
Recently upgraded to 500MBps, slower than anticipated speeds
Hi folks,
We've recently upgraded from 100Mb/s to 500Mb with the extra time spent working and streaming from home. While we've seen speed increases across all devices, they're quite shy of the 500Mb promised.
At the moment we've got our HUb 3 set up in modem mode connected via an Asus RT-AX86U router and on the one machine that's hardwired with Cat-7 cables to and from the roouter (overkill I know), we're only getting around 240Mb. This has been duplicated when I pllug the same cable into a laptop.
There now follows a ton of numbers I don't really understand at all. In browsing for possible solutions I've gathered that something is wonky with channels 23 & 24, and possibly 1?
Any help much appreciated!
-Mark
MarkyB52
  • 9
Message 2 of 9
Re: Recently upgraded to 500MBps, slower than anticipated speeds
1 402750000 -14.8 35 256 qam 30
2 202750000 -9.7 37 256 qam 9
3 210750000 -10 37 256 qam 10
4 218750000 -10.2 37 256 qam 11
5 226750000 -10.5 37 256 qam 12
6 234750000 -10.9 37 256 qam 13
7 242750000 -10.7 37 256 qam 14
8 250750000 -10.9 37 256 qam 15
9 258750000 -11 37 256 qam 16
10 266750000 -11.2 37 256 qam 17
11 274750000 -11.2 37 256 qam 18
12 282750000 -11.4 37 256 qam 19
13 290750000 -11.5 36 256 qam 20
14 298750000 -11.5 36 256 qam 21
15 306750000 -11.7 37 256 qam 22
16 314750000 -12 36 256 qam 23
17 322750000 -12.2 36 256 qam 24
18 330750000 -12.7 36 256 qam 25
19 370750000 -13.3 36 256 qam 26
20 378750000 -13.4 35 256 qam 27
21 386750000 -13.8 35 256 qam 28
22 394750000 -14.3 35 256 qam 29
23 410750000 -15 34 256 qam 31
24 418750000 -15 34 256 qam 32
1 Locked 35 771 0
2 Locked 37.6 6 0
3 Locked 37.6 9 0
4 Locked 37.6 21 0
5 Locked 37.6 21 0
6 Locked 37.6 6 0
7 Locked 37.6 11 0
8 Locked 37.3 10 0
9 Locked 37.3 9 0
10 Locked 37.3 17 0
11 Locked 37.3 8 0
12 Locked 37.3 9 0
13 Locked 36.6 18 0
14 Locked 36.6 11 0
15 Locked 37.6 9 0
16 Locked 36.6 9 0
17 Locked 36.3 18 0
18 Locked 36.3 11 0
19 Locked 36.6 16 0
20 Locked 35.5 63 0
21 Locked 35.5 56 0
22 Locked 35 248 0
23 Locked 34.3 3783 0
24 Locked 34.3 1667 0
MarkyB52
  • 9
Message 3 of 9
1 53699981 4.9 5120 64 qam 13
2 25799983 4.65 5120 64 qam 12
3 32599974 4.75 5120 64 qam 11
4 39400017 4.9 5120 64 qam 10
1 ATDMA 0 0 0 0
2 ATDMA 0 0 0 0
3 ATDMA 0 0 0 0
4 ATDMA 0 0 0 0
MarkyB52
  • 9
Message 4 of 9
11/11/2020 20:03:48 notice LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/11/2020 20:03:37 Warning! LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/11/2020 01:00:41 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
09/11/2020 19:14:59 notice LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
09/11/2020 19:01:35 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
09/11/2020 10:29:10 notice LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
09/11/2020 10:24:32 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/11/2020 15:00:26 notice LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/11/2020 14:23:47 notice DHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt057-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/11/2020 14:23:47 Error DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/11/2020 14:02:6 notice LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/11/2020 14:01:8 Warning! LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:01:30 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/11/2020 13:55:23 notice SW download Successful - Via Config file
08/11/2020 13:53:17 notice SW Download INIT - Via Config file
08/11/2020 13:53:8 Error Disruption during SW download - Power Failure
08/11/2020 13:50:20 notice SW Download INIT - Via Config file
07/11/2020 18:34:32 notice DHCP Renew - lease parameters tftp file-cmall-any-cancel-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
07/11/2020 18:34:32 Error DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:01:40 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
Anonymous
Not applicable
Message 5 of 9
Your downstream power levels are too low (In spec is -6 to +10).
Upstream power levels are quite high, but in spec.
Do you have one of these fitted?
MarkyB52
  • 9
Message 6 of 9
Thanks for the quick reply Carl. No, nothing like that going into the Hub.
Cheers,
-Mark
Anonymous
Not applicable
Message 7 of 9
Cheers,
-Mark
You'll need an engineer visit to correct the levels.
MarkyB52
  • 9
Message 8 of 9
Righto. Thanks Carl, I'll get a comfy chair and give VM a call tomorrow. Nice one 👍
-Mark
Anonymous
Not applicable
Message 9 of 9
-Mark
8am if you can, when the lines open.
